Results 1 to 8 of 8
    Confused Liquid refrigerant in hose to recovery tank after purging
    After purging my recovery machine and shutting off all valves, sometimes when I go to disconnect the hose to the tank there is still liquid refrigerant in it. I have a sight glass on the tank's liquid valve and can see it fill with the liquid refrigerant if I don't shut off the tank's liquid valve quick enough. Thoughts on why is this happening? Do recovery tanks have a check valve in the liquid valve?
    Nov 2014
    Chicago Illinois
    Had some with check valves and some with out what happens is all that gas refrigerant condenses in the hose.
    Dec 2009
    maroon lazyboy
    ‘De Minnie Mouse says you will be ok
  4. Likes CircusEnvy liked this post
  5. #4
    Jun 2018
    Boise, ID
    I don't know of any recovery machine that forces absolutely all the refrigerant from the discharge line into the recovery tank. The ones I've used leave the line still pressurized and depending on the conditions, I have also seen small quantities of liquid refrigerant while disconnecting.
  6. #5
    Feb 2017
    New York
    Recovery machines can only remove the liquid from their own condensers. There is no way for them to clear the hose of liquid. It happens on a regular basis for me. The only time I don't see it is if it's a hot day and I'm cooling the tank off with a garden hose. The tank will be at a lower temp than the hose so the refrigerant will want to be in the tank instead.
    -----Stop, step back, relax and have another go at it.-----
  7. #6
    Dec 2014
    You pick the recovery unit up over your head and let it drain into the tank. Works like a charm.
    Sent from my SM-G930V using Tapatalk
  8. Likes BennyD liked this post
  9. #7
    State College, PA
    Quote Originally Posted by icy78 View Post
    Sometimes it is hard to tell if this is a spoof or not, until you get done reading the whole post and think about it for a second or 2.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
  10. #8
    Dec 2014
    Hence the Pinocchio face. Didnt his nose grow with each fib? Been a while but thats how i remember it.
    Quote Originally Posted by joemach View Post
