Results 1 to 10 of 10
    Feb 2015
    Ohio
    Whole house water filter
    Whole house water filter before or after softener?
    "If common sense was so common, everyone would have it."
    Feb 2017
    New York
    City or well water?
    -----Stop, step back, relax and have another go at it.-----
    Feb 2015
    Ohio
    Well
    Feb 2017
    New York
    I have my filter before my softener. I'm on well water too.
    Apr 2018
    Sagard, Germany
    I have the softener first, and then the filter.
    Feb 2017
    New York
    Quote Originally Posted by mariner59 View Post
    I do have iron bacteria so I chlorinate my well every so often. It catches the crap that I get before plugging up the media... Learned the hard way. Wasn't too bad, a few back flushes and it was ok.
    Apr 2018
    Sagard, Germany
    Quote Originally Posted by BennyD View Post
    That makes perfect sense in your case.
    My filter is in the kitchen, and my softener is outside. I live near Manila in the Philippines and our water has so much silica in it, that you can not even wash a car properly with it. So the softener comes first, and then only the water we use in the house goes through the filter. The filter last a bit longer that way.
  8. Likes BennyD liked this post
  9. #8
    Feb 2015
    Ohio
    I piped it in before the softener. There are no really high levels of anything in our well water, just hard enough to leave mineral deposits on glassware without a softener. I did however discover the pedestal sump pump apartment just failed again in the reservoir the softener drains into. Unfortunately there are no floor drains close by. About 2 years ago I had to replace it, bought the only pedestal pump lowes had and it only has a 1 year warranty. Thinking about getting a different style pump and a smaller reservoir this time.
  10. #9
    Sep 2018
    Depends on the media type inside the whole house filter. If it's simply charcoal, install as a post filter after the softener to take care of taste and odor problems. Iron removing filters (eg. with katalox light media) are installed before a softener.
  11. #10
    What ever you do, do not install your softener or filter before your well pressure switch. Unless of course you want to do an extreme basement flush out.
    Retired, after 43 Years
