Page 4 of 4 FirstFirst 1234
Results 40 to 42 of 42
  1. #40
    Winnipeg,MB,Canada
    Isolate the filter, the regulator can be removed, no need to pull refrigerant
  2. #41
    Aug 2018
    Columbus,Ohio
    Finally pulled the charge out and its a 190lbs off. leak checked and found that the suction elbow is leaking. Could find anything else haven't made it to the oil regulator maybe tomorrow.
    Sent from my SM-G955U using Tapatalk
  3. #42
    Aug 2018
    Columbus,Ohio
    Found some debris on the diaphragm and a sliver of loctite. Also had a little gouge in it.
