Page 3 of 3 FirstFirst 123
Results 27 to 33 of 33
  1. #27
    Sep 2018
    Quote Originally Posted by Chev5372 View Post
    You could use a dry cooler on the roof , no need to worry about oil traps.
    What is a dry cooler? Can you include a link to a video of how they work?
  2. #28
    Sep 2018
    The hood system is fine and efficient. Our load calculations factor in the following and still require 17 tons of conditioned ventilation air:
    3400 sqft.
    800 sqft open kitchen with 14' hood range, 2 fryers, pasta cooker, small charcoal grill, 8 burner stove, and double stock pot burner.
    Walk-in condenser unit heat will be displaces... somehow.
    Ice machine condenser unit heat will be displaced.
    100 seat capacity with alcoholic beverages being 35-45%of the sales. Meaning, it will feel hot after a couple of drinks.
    South and West entrances with only 3 windows.
    All of that being said, the owner is going to put a total of 19 tons up on the roof. If I where to place the condensers in the kitchen then 5 tons of a/c would be required to handle just the heat load off of that. So that is completely out of the question.
  3. #29
    Dec 2014
    New Mexico
    A dry cooler is a coil with fans to draw air across the coil. The coil and piping between the roof and condenser are filled with glycol. You would have a water ( glycol) cooled condenser at the walk in with a pump to move the glycol. You could tie in the ice machine as well. Everything needs to be sized properly since glycol is not as efficient as water but with the right percentage no need to worry about freezing in the winter or worry about compressor oil return with long refrigerant lines.
    Should be able to find images on line from Mueller, Baltimore air coil and Heat Craft.
    Sent from my iPad using Tapatalk
  4. #30
    Southeastern Pa
    Quote Originally Posted by restaurantowner View Post
    3400 sqft.
    I have done a lot of chain restaurant work, and I find that most charcoal grills have their own ducted exhaust. Is that the case here?
    Is all exhaust going to be on the side of the first floor wall?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  5. #31
    I wonder if he meant charbroiler … where it has nat gas with lava rocks
  6. #32
    Jan 2015
    Iowa
    If you can't use a water cooled unit, and I saw it was said there is no room on the ground outside, can a condensing uint be hung on the wall outside (in back or side with a service platform)
  7. #33
    Sep 2018
    So, we are looking at a robata grill, which is a form of a charbroiler that uses indirect heat. We are placing all of the equipment under 2 hoods in a straight run. the grill will be beside the fryers.
    So the run of equipment would be the following:
    Pasta cooker, then 8 burner stove, then charbroiler, then 2 fryers, then 2 stock burner.
