Results 14 to 21 of 21
    May 2014
    Bay Area California
    Appreciate the full disclosure.
    I use 56% silver on everything except steel.
    Did you really need the " If you were a real tech " ??
    Jul 2010
    Melbourne / Victoria / Australia
    Quote Originally Posted by RussellHarju View Post
    Check out the Fieldpiece MR45. Full disclosure, I work at FP. The MR45 has a DC motor that allows it to ramp up after the liquid stage to pump gas faster than your typical AC motor.
    https://www.fieldpiece.com/products/...overy-machine/
    Thanks for being transparent, now the next big question, how far along is the 230v 50Hz model going to be?
    Jul 2018
    Wisconsin
    MR45INT
    Sent from my SM-G960U using Tapatalk
    Houston,Texas
    Quote Originally Posted by AIRCON8 View Post
    I'm on the market for a recovery machine
    i have always worked with APPION but i never like it
    i was thinking about two other brands
    JB and INFICON
    Which one is better and why ?
    Yaw do realize this thread is a year old, right?
    “Experience is a hard teacher because she gives the test first, the lesson afterwards" ~ Vernon Law
    "Skilled Labor Isn't Cheap, Cheap Labor Isn't Skilled" ~ Unknown
    "When the teachers become unteachable we're all in trouble"
    "It's what you learn after you know it all that counts." ~ John Wooden
    Jul 2010
    Quote Originally Posted by Spitz View Post
    MR45INT
    Last I checked at a parts house they weren't available yet according to FP Aust
    Oct 2009
    Atlanta,Ga.
    I have an Appion ,I have no problems with it.I have had it before the Fieldpiece unit came out.if i had to buy a new reclaimer,I would look at the new fieldpiece.It is suppose to be good.
    Jul 2019
    St Joseph, MO
    g5 appion all the way! with or with out a ice bucket or cooler. I have the field piece one too. can't remember the model, but the g5 is lighter
    Nov 2014
    Australia
    Quote Originally Posted by Bels View Post
    I’ve had a MR45 since near the start of the year, I had to get Actrol to special order it, potentially one of the first to come in maybe?
    I’ve got both the Appion and the FP and I prefer the FP, however the serviceability of the Appion is hard to beat - I had a TR21 early on and it needed a rebuild which could only be done by a CPS rep for scored bores and only got another 2 runs before it scrambled the bores again.
