Results 1 to 13 of 22
    May 2018
    FLORIDA
    Confused FLUKE 902 AND SHORT COMPRESSOR
    Long story short
    i have a Fluke FC 902 a very nice, and expensive, clamp meter.
    Today i was homing a shorted compressor for the first time with this meter, and was showing OL.
    So i checked with my cheap Fieldpiece SC 53 and was showing a short to the ground, something like 25 ohm.
    i can't believe that a expensive meter made just for HVAC by Fluke is reading K ohms and not m ohms
    am i doing something wrong ?
    Nov 2014
    Portland, Oregon, United States
    Nope, it just doesn't have the range. I am a fluke fan, never have cared for the fieldpiece meters. Your 902 will measure to 9999 ohms. Buy a megohm meter, the 902 is a nice clamp meter. On a side note, see if they will repair it.
    Sent from my SM-N950U using Tapatalk
    Years ago when they first teased about it, I was excited that Fluke was making a HVAC specific clamp meter.
    Then I saw the specs for the 902 and dismissed it because its ohms function is useless for motor diagnostics.
    May 2018
    FLORIDA
    Thanks to Fluke i mis diagnosed a blower motor and almost a compressor
    Dec 2012
    columbus, OH
    Needs atleast .5m
    Chicago area
    Quote Originally Posted by AIRCON8 View Post
    Long story short
    There may be something wrong with the meter, or the leads.
    Lead to lead on ohms what do you read?
    I would think the meter should pick up on 25 ohms to ground
    Unless you meant Megohms.
  7. Likes mgenius33 liked this post.
  8. #7
    May 2018
    FLORIDA
    what fluke clamp meter will read Mega Ohms
  9. #8
    Nov 2014
    87v, I used the 116 for years. I dont remember its scale though. Imho, even though I use the 324 for amprage readings, flukes clamp meters are really just throw away. They wont even offer repair on them.
  10. #9
    May 2018
    FLORIDA
    so no megohms on fluke clamp meters ??
  11. #10
    That is a residential meter at best. If you are going to do more advanced measurements then throw that thing away.
    "Right" is not the same as "Wise".
  12. Likes Bels liked this post.
  13. #11
    May 2018
    FLORIDA
    Confused
    Quote Originally Posted by jayguy View Post
    Its a good clamp meter, i got it 2 weeks ago but soon i've found out thats not reading megohms, and im not going to buy a DMM i cannot afford it and not enough space in my bag. As much as i like the Fluke its useless for me.
    and so far i didn't find any Fluke clamp meter with megohms function am i right ?
  14. #12
    Years ago Flucks better clamps did not do ohms or voltage with no place for leads. Anyone serious ain’t using a clamp for that.
  15. #13
    Jul 2010
    Melbourne / Victoria / Australia
    Specs here list 60 k ohm max range. https://www.fluke.com/en-au/product/...s/fluke-902-fc
    Doesn't matter how much you flog a dead horse, no clamp meter is going to be able to read to the range that an actual multimeter will read up to. Maybe wherever you purchased it from will let you return it as it doesn't do what you think it will do. A lesson learnt to check specifications before you pull the pin and buy a meter.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
