Page 4 of 6 FirstFirst 123456 LastLast
Results 61 to 80 of 119
Thread: So, still nothing from Northpark on wireless probes huh?
  1. #61
    Quote Originally Posted by Bill Northrup View Post
    Hello Pacnw, Do you use our platform frequently?
    As often as I can.
    As has been stated, for residential split systems those pipe straps wire lengths are just annoying.
    Also, a $300 static pressure probe that is limited in its use. If I recall correctly, it cannot differentiate supply and return static without disconnecting one of the hoses.
    It just seems like those of us that already own this platform have been left in the dust. We helped, by purchasing it, finance things that are given away to others that bought nothing. When we ask for improvements we get open ended promises and minimal results. IE- magnetic probe sleeves.
  2. #62
    Dec 2016
    Ellicottville NY
    Quote Originally Posted by pacnw View Post
    As often as I can.
    Pacnw, I know its seems that we have done nothing but there has been a great deal of effort over the past 2 years. By the end of this year we will be introducing new software and hardware that current and future iManifold platform users will benefit greatly from. Since I don't know who you are please email me: bill@npinnovations.com and we can have a discussion. Thanks for the input.
    Bill
  3. #63
    Chicago area
    What size range would you like to see?
    I would like to see similar to what you have in the strap on type - those go to 4 or 5
    Standard clamp type up to 2 1/8 would be good.
    Or maybe just a clamp that can accept the strap type for faster connections on smaller sizes. - thats how appion does it and its really slick.
  4. #64
    VA
    Quote Originally Posted by heatingman View Post
    Now, that would be nice!
    "The only true wisdom is in knowing you know nothing" Socrates
  5. #65
    Dec 2015
    Washington, DC
    I agree with heatingman. Something that can clamp in the 2 inch range would be awesome, especially if wireless.
  6. #66
    Bill
    I does not matter who I am, just that I am a disappointed customer who, like many others, feels they are ignored and taken advantage of.
    Your competition has met or exceeded what the platform was initially when it debuted. Other software far exceeds yours, other hardware has listened to input and brought to market items(wireless temp clamps) we asked for, and the interaction with the platform has all but disappeared.
    As stated, we have been told positive things are coming, but when? When asked about the platform by other techs, I just can't endorse it as I once did. I bought it and live with it, but I am buying into the other(in my opinion better) options on the market.
  7. #67
    Dec 2016
    Ellicottville NY
    Thanks for the feedback. Good ideas....Best, Bill
  8. #68
    Dec 2016
    Ellicottville NY
    Let me know how many short thermistors you would like.....
  9. #69
    Chicago area
    4? What do you mean?
  10. #70
    VA
    What is inside radius sized for with the existing strap sensor? I'd imagine we may lose a bit of accuracy with a sensor that expanded the range from 5/16 to 2-1/2".
    The sensor itself would likely need to be segmented for flexibility while maintaining maximum surface contact, no?
    On a separate note, I would love to see my dual port manometer read both measurements as well as the differential simultaneously.
    As I said previously, I think you've done a good job with reducing drift compared to others on the market with exception of high end auto-zeroing manometers, but the fact that I have to reconfigure the probe to check the measurements independently is a bit frustrating.
  11. #71
    Dec 2016
    Ellicottville NY
    Quote Originally Posted by mgenius33 View Post
    to achieve accurate reading we would need to use another thermistor design. The coopers have a radius that would not allow good readings on a 2.5" pipe. We will look at some options to get that done.
  12. #72
    Dec 2016
    Ellicottville NY
    Related to your question regarding the manometer. the sensors in our manometer only allow one reading at a time such as the differential across an evaporator. We are exploring creating a dual port manometer that can provide two separate measurements.
  13. #73
    At The Point Of No Return
    You can use a 4011 on a flat surface if you want. 2-1/2 inch is no problem.
  14. #74
    I'd be surprised if you could do better than a Cooper 4011.
    The size pipe is not a issue for it.
  15. #75
    Dec 2016
    Ellicottville NY
    Good to know. They do have a radius on the contact portion of the thermistor. Have you tested them on a 2-2.5" pipe and experienced good results? Thanks!
  16. #76
    VA
    Can't a toggle be designed into the app on the main display, without having to go into the probe configuration settings?
    That's all that is needed.
  17. #77
    The micro gauge thermistor wire behind the small waffer thin copper contact pad has very low mass. The actual contact point on that pad has little to no affect on the reading.
  18. #78
    Dec 2016
    Ellicottville NY
    Thanks for the info. We'll have to try that with our chiller profiles.
  19. #79
    Jun 2011
    michigan
    We were also supposed to get water source heat pump profiles a few years ago. Any progress on those?
  20. #80
    Dec 2016
    Ellicottville NY
    Quote Originally Posted by kra2y View Post
    Yes,we expect to release our new app in October. This will be the foundation for our new features and improvements. We will have water cooled condenser, ground source and chiller profiles including much more. It might take a bit to get them all integrated working properly but that is the plan.
