Results 1 to 11 of 11
    Jul 2009
    Columbia, MD
    Re-piped an old boiler
    This boiler had all kinds of issues and could never get rid of the air.
    Wish I took before pics.
    Here is how we repiped it.
    All new piping, spirovent, backflow, prv, ex tank, oil lines
    May 2011
    Washington, DC
    Prior to leaving residential I always enjoyed piping boiler and did a lot of repiping as well. As you know damn near every one you come across is piped wrong, wrong expansion tank and pump configuration, no or wrong purge set up, etc.
    I can’t see it actually on the piping but your drawings lay it out nice. Looks good and I’m sure they’ll have a nice quiet system (Waterside. The burner is another conversation but the AFG isn’t too bad.) now.
    Regards,
    Ron
    Aug 2009
    Michigan
    Beautiful work! That is a boiler I would like to service. Nice clean solder joints. Pipping schematic is perfect. Customer will be happy😁
    Jun 2014
    Is the little "u" of pipe just after city water valve for movement, like a Hartford loop, or is it just because the existing valve was lower than you needed by a half inch or something?
    Looks great.
    Mar 2013
    Billington Heights, NY
    I dont like your sticker
    Apr 2003
    Maple Grove, MN
    The only nit-pik I have is where the copper goes into the steel. If you would have changed the black reducing couplings to brass, it would have been a lot better.
    This has to do with electrolysis. I can't explain the whole science behind it, but when you connect copper and steel together it can cause the steel to rust out really fast and leak at that point. Using brass (or dialectic unions) between the copper and the steel will act as a buffer between the 2 metals to help prevent this.
    Oh wait, I have another nit-pik... It would be nice to see isolation valves on top of those zone valves and maybe unions to make changing them out easier.
    Other than that, it does look good. You did a nice job with the soldering. Also, the gauges on each side of the pump is a nice touch.
    If at First You Don't Succeed, Skydiving Is Not for You.
    Jan 2012
    Broomall, PA
    You usually don't have to worry about oxygen corrosion or electrolysis on a closed hydronic system. Steel to copper happens all the time with no problem.
    Uh...Google it yourself!
    Jul 2009
    Columbia, MD
    Quote Originally Posted by dnr View Post
    Looks great.
    Its because it was to low
    Jul 2009
    Columbia, MD
    Quote Originally Posted by HVAC_Marc View Post
    Yea. Should have ripped it off. Thats who has serviced it forever
  10. Likes HVAC_Marc liked this post
  11. #10
    Jul 2009
    Columbia, MD
    Quote Originally Posted by ammoniadog View Post
    So I understand the electrolysis. On closed loops that never get new water added, you wont have an issue.
    Where i have seen issues, is in city water, or systems that have lots if makeup water added.
    Thanks for the heads up.
    For the valves would be nice for shutoff. I made it super easy to purge it though.
  12. #11
    Jun 2012
    Northern NV
    Electrolysis happens anytime there are dissimilar metals in an electrolyte, which in this case is the water in the system.
    Open systems suffer from corrosion in addition to electrolysis.
    Speed of destruction is dependent on the pH of the water in the system. Low pH=high amount of electrolysis. One possible reason to use an additive perhaps?
  13. Likes gravity liked this post
