Results 1 to 13 of 16
    Aug 2018
    Goodman Heat Pump and Nest
    My prior Nest Thermostat died and I received a replacement. The original was installed my HVAC guy who is now out of business. I have a Goodman 5 ton heat pump (DSZC18). It is two-stage. When looking at my HVAC's wiring, I don't see the two stage wires as they should be from what I've read in the Nest Pro Installation manual. There's also a wire he labeled as * that has no function on the Nest per his programming.
    What do you suggest for confirming correct wiring of a Goodman 2-stage heat pump? Prior to needing to replace my nest cold and hot air was working fine. I'm worried the system wasn't being used efficiently by the Nest or using the 2-stage setup.
    I included pictures of the wiring I have, the Nest programmer, the Nest Pro manual, and the DSZC18 wiring diagram.
    Thanks!
    Mar 2013
    Billington Heights, NY
    looks like he'd gone and botched it. call him back
    Jun 2014
    Dover, DE
    That thermostat is not wired for a 2 stage outdoor unit. It is wired for 2 stages of heat.
    Nest is a terrible choice for a thermostat. You were tricked by a large advertising budget for an at best mediocre product
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    Southold, NY
    Let me give you an honist opinion .....
    NEST
    SUCKS
    Jul 2013
    Richmond, VA
    I suggest having a professional come out and verify which wires go where because if that's how it was originally wired, there's no way you were utilizing your two-stage heat pump. And electricity doesn't care about wire colors, so it's anyone's guess what that wire under * goes to.
    Southold, NY
    Did I say NEST
    SUCKS!
    Jan 2014
    New England
    Ran out of wires, possibly there is another wire behind the Sheetrock.
    Can't say I seen another green wire on the RV....sounds like they ran two separate wire bundles.
    This is confusing.....two greens and two whites....
    Looks like at least one transformer...
    Aug 2018
    Thanks for the feedback. At least you confirmed he was an idiot which I suspected.
    Is the Nest that bad? For a Goodman 5 ton heat pump, does it make much of a difference what thermostat I use?
    I based my decision on wirecutter's review comparison between Ecobee and Nest. The Honeywell thermostat was initially recommended, but I didn't like the interface and smart features.
    Ecobee is a much better thermostat.
    Jan 2014
    New England
    Possible they tied the 2 stages into one stage as your Y2 is not hooked up, guessing you have auxiliary heat?
    Paying for two stage and getting one stage?
    Quality question to ask the Installing Contractor
    Aug 2018
    For the past year it seemed to work. Got cold air and hot air. By not using two stages, how efficiency am I losing?
    Aug 2018
    I dont have an auxiliary heat that Im aware of. Just the Goodman Dcsz18.
    Quote Originally Posted by whyme1465 View Post
    Well, no way to put a true percentage on it. And you are also loosing a good bit of its comfort ability.
    I don’t have an auxiliary heat that I’m aware of. Just the Goodman Dcsz18.
    Aux heat would be in the air handler, and not something you readily see.
    Call a qualified service tech out to fix all of the low voltage wiring issues.
Tags for this Thread
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
