Page 3 of 3 FirstFirst 123
Results 27 to 38 of 38
  1. #27
    VA
    Quote Originally Posted by heatingman View Post
    That outer sleeve might be your problem.
    The coupler is meant to absorb some of the vibrations.
    The coupler is still absorbing vibrations, the switch fell out due to it being bumped. It’s in a pretty poor location without protection.
    I’m going to install a clamp over the switch so it won’t get damaged again.
    I agree a 2 stage will pull deeper more quickly, but I just wonder how much difference it would show in a real world test. It’s not like I’m going to buy a single stage.
    "The only true wisdom is in knowing you know nothing" Socrates
    Visit us at Dr. Degree°s HVAC
    or like us on Facebook
  2. #28
    VA
    Problem solved!
    Just picked up a brand new in box, JB Eliminator 6cfm pump for $150 at a pawn shop. Didn't even have the oil opened yet. Tested it at. <19 microns.
  3. Likes heatingman, Zamoramax liked this post
  4. #29
    Chicago area
    Quote Originally Posted by mgenius33 View Post
    Problem solved!
    Thats a good find.
  5. #30
    State College, PA
    I have a 10 year old 5 cfm Platinum and the only thing I have had a problem with is the rubber legs. I just seem to keep loosing them. I can still pull down a system below 75 microns.
    I would buy another is a heartbeat.
    Just wish JB sold the oil in containers to match the capacity of each pump. When I fill with new oil sometimes it is hard to see when it is at the center line. I have overfilled many times and had to drain out some of the new oil. Maybe I need to pay more attention to what I am doing.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
  6. #31
    Aug 2015
    Buffalo,NY
    Quote Originally Posted by joemach View Post
    I fill a container already marked with the correct amount for my pump then dump it in. Makes life so much easier.
  7. #32
    State College, PA
    Quote Originally Posted by Metalman0880 View Post
    I have been meaning to do that for a long time. Just never on the top of my priority list.
  8. #33
    VA
    Will this intake cross fit the Eliminator. This is what my Platinum uses, with exception of the 1/2" port.
    https://www.ebay.com/itm/PR-76-J-B-I...-/162902401104
    Apparently the PR-24 has been discontinued. Anyone know where I can get one. I'd rather have two 3/8" ports than the 1/2" port.
    I guess if my Platinum fails, I can just take it off and install it on the Eliminator.
    How many of you carry two pumps on your truck?
  9. #34
    State College, PA
    I used to carry 2 pumps. Now down to 1.
    I would call JB to see if that fitting would work on the Eliminator. I am sure they would give the best answer. I Have the Platinum on the truck, but an Eliminator in the shop as back up.
  10. #35
    Chicago area
    I carry 2 pumps on the truck. Both are JB Platinums. The thread size that goes into the pump is 3/8 npt on both.
    As far as the eliminator series, I dont know, but I would assume 3/8 npt also. Just remove it and try to swap with the Platinum, that will tell you 100 percent.
    As far as wanting 2, 3/8 ports and a 1/4 cross.
    Just take the 1/2” port on the cross tee that is available, and install a 1/2” female x 3/8 male flare adaptor. Thats what I did when I was still using the appions.
    United or another refrigeration house should have them. And just leave it permanently installed, and get another 3/8 cap and you will be set.
  11. Likes Zamoramax liked this post
  12. #36
    It's the same thead on both JB models
  13. #37
    Aug 2018
    I have two JB's. I bought them years apart. One was new. One was used. I've rehabbed them both over the years, and both before they ever broke down. If you're making your living with a piece of equipment, in my opinion, cheap is not the way to go. BTW, most mechs I know never seem to be entirely comfortable when they have to drag out the cheap stuff in a pinch. Just my opinion.
  14. #38
    Jun 2006
    Palm Harbor,FL. (moved from PA.)
    I"d Go with yellow jacket super evac 6cfm,good for everything except if you working on a bigger roof top its nie to put two pumps in the system for speed.
