Results 1 to 13 of 30
    Caledonia WI
    Heat absorbing putty
    It's not what you're capable of doing that defines you, it's what you do on a daily basis.
  2. Likes taylor2, Nuclrchiller liked this post
  3. #2
    Oct 2014
    Columbus, Ohio
    Is that the uniweld Cap'n hook torch tip, or is it something else?
  4. #3
    Aug 2018
    Piedmont Triad, NC
    Looks nice and neat. Good idea with the heat shield. I usually use a small cotton welding blanket on mine. Forgive my ignorance but is that staybright 8? I've heard of people using it but I've never tried it. Over here we have to shield the low voltage wire when it runs outside so carflex is our best friend.
  5. #4
    Caledonia WI
    Smith Quick- Braze
    Quote Originally Posted by rjk_cmh View Post
  6. #5
    Caledonia WI
    It's Harris Safty-Silv 50 silver brazing alloy
    Quote Originally Posted by Achso017 View Post
  7. #6
    melted the hose?
    Keep it simple to keep it cool!
  8. #7
    Caledonia WI
    It's leftover tape, from taping it to pipes to run nitrogen through them.
    Quote Originally Posted by stanbyyourword View Post
    melted
    the hose?
  9. Likes stanbyyourword liked this post
  10. #8
    Aug 2018
    What type of torch is that?
  11. #9
    Aug 2018
    Piedmont Triad, NC
    Wow. Those braze joints are amazing then. No crowns or under globs. Nice work.
  12. #10
    Those finished joints look Really nice.
    What work was done to them and the lines set ends between the time the torch was removed until this picture was taken?
    PHM
    Quote Originally Posted by billg View Post
    PHM
  13. #11
    Caledonia WI
    Just a little sanding to remove flux and even out the color. High silver bearing silver solder is expensive, not something you want globbed up and dripping all over.😀
  14. #12
    Caledonia WI
    Smith Quickbraze
  15. Likes Elmaiko liked this post
  16. #13
    Hell; I don't want even the least expensive solder globbed up and dripping all over. <g>
    That silver soldering wire really Does flow nice, doesn't it? I am always happy using it. I use it fairly often bought a case of it some years ago at a bankruptcy auction sale because it was labeled: Tie Wire <g> I forget the exact winning bid at this point but I'm sure it was less that $5.00 <g>
    I recognized the clean-up because one time, in an early-on tech school setting, a soldered-up series of 3/8" OD copper swedge joints was shown to me as the example of the standard I should be aspiring to and working towards achieving.
    The actual project was to create a working example of The Basic Refrigeration Cycle.
    I was welding and soldering and brazing when I was 13-14 years old - I knew how to solder. But it took me a while to realize what their trick was. The joints were all perfect - because they has been dressed to perfection. There wasn't even that little tinned-spot where the solder wire had first touched the joint. <g>
    The second second I saw your picture that long ago incident immediately popped into my head. <g>
    PHM
    Just a little sanding to remove flux and even out the color. High silver bearing silver solder is expensive, not something you want globbed up and dripping all over.��
    PHM
