    May 2018
    Replacing recessed lighting
    So, I have the following type of setup
    Which has the open bulb style(which we son’t like). Is there a specific kit to make it look like the retrofits? E.g.
    Mar 2013
    Billington Heights, NY
    I just got a cheap Incandescent Can for direct insulation contact, off of lighting direct dot com and used an LED Retrofit kit. That way if the utility fries the led, i just replace the retro fit. Nice thing is, it looks like you can get to the fixture easily from the back. I did mine all from below, and they where the mini spots. Wasn't going to climb 60 feet in the attic, on the other side of the triple chimney.
    Retired, after 43 Years
