Results 14 to 26 of 48
    Jan 2005
    Akron
    Quote Originally Posted by Boiler Guy View Post
    Would you recommend using MQ on a commercial unit, something like a Daikin SWP, multi circuit water source unit? Or is it mostly just for residential? I’ve yet to use apps and wireless probes, but I want to get into it. I’ve been leaning toward iManold probes because of the pipe straps for larger stuff.
    MQ is fine for commercial. Right now it is geared toward single stage equipment, but we are adding in a multi-circuit mode soon. The software can be used with Testo, Fieldpiece, and iConnect/iManifold. Right now for commercial, the strap probes provide the most flexibility for sure.
    JLB,
    Dec 2015
    Washington, DC
    Quote Originally Posted by jim bergmann View Post
    I’m torn. I feel like if I drop the ridiculous money on iConnect, Testo or FP will come out with a strap probe or something similar.
    Are the iConnect strap sensors the same as the Cooper Atkins ones?
    Jan 2005
    Akron
    Yes they are.
    JLB,
    Chicago area
    Boilerguy, for what its worth, I bought the set up and hardly use. Only when I need the range.
    Dec 2015
    Washington, DC
    Quote Originally Posted by heatingman View Post
    What do you like using on commercial stuff?
    Did you ever end up buying a laser alignment tool? Lol
    Chicago area
    Not yet on the laser. Most times I use the Appions. Wish I bought the laser instead of the Iconnect.
    Dec 2015
    Washington, DC
    Yes they are.
    So with MQ, could I use Fieldpiece pressure probes with iConnect temperature straps?
    Chicago area
    Yes, but you need at least the i connect hub, or the I manifold to be able to plug the temp probes into, but without the pressure probes to go along, the user mapping may be limited.
    Dec 2015
    Washington, DC
    I’ll just stick with my Appion gauges then. Maybe one day...
    Dec 2013
    Russia
    Hi Jim, when we can see Bar and C in that soft?
    Sep 2019
    Imanifold
    Since I designed them both, I can tell you for sure MQ is. It is the second generation and has many more diagnostic calculator and indicators. That said, garbage in produces garbage out. Make sure that you pay close attention to the profile of the system. Flags are "symptoms of" Symptoms of a liquid line restriction might be low liquid pressure, low suction, and liquid line temp below ambient for example. An undercharge would have both of the same.
    I know this post was very old but do you still think quick measure is still better then imanifold? Ans also do you like test or the iconnect probes better?
    Dec 2013
    Russia
    Quote Originally Posted by Jasonzuni View Post
    quick measure dont have second circuit...
    And im using only oldschool imanifold software. v 2.0 not for me.
    Deep Southeast
    I have both iManifold and FP. FP with MQ is much easier to use. FP is much more compact & portable...also the wireless pipe clamps make it very worthwhile, plus with iManifold, you have to carry the iConnect base as well as the probes (and iManifold's pipe clamps have to be plugged into the base or a pressure probe or extender).
    The iManifold is a good system, but sits in my office. I don't feel like I've missed anything using the FP probes with MQ.
    As to the app comparison, MQ wins hands down, IMO. MQ is better than the iManifold app, the Testo app and much, much much better than the FP app. It blows away all competitors. I do Residential and light commercial.
