Results 1 to 8 of 8
    Aug 2014
    need to correct temp on meat display
    hello I will be replacing deforst timer on a meat display refrigerator R134A,the case doesnt have fans only 2 evap coils top & bottom, i have set the pressure control to 40psi & differatial to 27psi,going off by pressure temp this the correct range for meat display for the product,but the customer says that the temp in the case reads 54°,any suggestion would help to maintain correct temp in the case, am new to refrigeration I mainly do hvac but to learn I have to work on them, so please dont criticize me for sounding rockie.
    Oct 2011
    Chicagoland Area
    Don't measure the air temp. Put a thermometer in a cup of water inside the case. Return the next morning and check the water temp. Adjust you control based on the water temperature.
  3. Likes crazzycajun liked this post.
  4. #3
    Dec 2014
    I'm thinking that it's more like 10, 11, or 12 , cut-out and high twenties for cut in. (PSI) And then you'll have one long defrost , say 1.5 hours, if it's the deli type case I'm thinking of.
    Sent from my SM-G930V using Tapatalk
  5. #4
    Aug 2014
    will follow your instructions thanks
  6. #5
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by nytech28 View Post
    Do you understand why? Following instructions for the sake of following instructions will not make you a better tech.
  7. Likes icemeister liked this post.
  8. #6
    Dec 2014
    Also, is it self-contained or remoted? If remoted its nice to have a suction stop solenoid rather than pumpdown. Pumpdown will freeze the frost hard on the coil, and its tough to thaw that on gravity coils.
    Mine build some ice during the day, but at night, when the product is covered, it has its long defrost. Then if there's any dripping, it doesn't land on the product.
    Sometimes they have to get used to seeing the ice, but it'll work.
    I generally have the stat sensor in the coil but you're using p-switch so no biggy there.
    As 2sac said. They should temp the product. Or water, glycerin, something like that. At least a large mass thermometer.
  9. #7
    Southold, NY
    We need make and model #’s
    Depending on the case store humidity must be below 75% and 75*F
    Most cases look for 28* discharge air but that’s a general #
    16 CI
    11-14 CO
  10. #8
    Aug 2014
    your rite, but working first time on refrigeration system isn't bad idea to learn from other techs.
