Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 48
  1. #27
    Aug 2014
    I didnt measure oil temp but based on the amount of oil theres a lot of liquid being backed up in the condensor but I do feel low air based on motor amp draw, the property supervisor dont believe air flow is problem due to not being issue in the beginning.
  2. #28
    Aug 2014
    if they call me back to repair the unit,I will be recovering freon, replacing drier & add a oil separator.then charge with SC & SH, the install manual recommanded traps be installed on suction pipe on risers,which i dont find being 1 3/8 suction rising more then 50ft.
  3. #29
    Mar 2015
    Medford, N.Y.
    So,increase air flow,put more BTU into the evap coil,more BTU into the comp,more BTU outta the comp,mamamamore BTU into the cond coil?
  4. #30
    Aug 2009
    Beatrice, NE
    Does this system have a TXV?????
  5. #31
    Mar 2015
    Medford, N.Y.
    Pull out as much freon as it takes to just show the beginning of activity in the SG. How does "the system" run then???.Then, slowly, re-analyze,re-think,re-see.
  6. #32
    Mar 2013
    Treasure coast, FL
    Quote Originally Posted by BNME8EZ View Post
    Do 15 ton units even come with cap tubes or fixed orifices?
    Sent from my Moto Z (2) using Tapatalk
  7. #33
    Aug 2009
    Beatrice, NE
    Quote Originally Posted by shellkamp View Post
    Not that I know of but there was no mention of checking the TXV and the symptoms sound very much like a bad TXV.
  8. #34
    Southold, NY
    I keep hearing air flow problems so thats what Im basing it on.
    No supporting #s
  9. #35
    Aug 2009
    Beatrice, NE
    I keep hearing air flow problems so that’s what I’m basing it on.
    No supporting #’s
    He has a 15* sa/ra split, does that sound like low airflow.
  10. #36
    Southold, NY
    With 9* SH
    YES
  11. #37
    Aug 2009
    Beatrice, NE
    With 9* SH
    YES
    But he also has a liquid line below ambient, so how accurate are they.
  12. #38
    Mar 2015
    Medford, N.Y.
    Cripes, start out w/ "something" close to normal, like a very close to normal head press and see how the rest of the system reacts.
  13. #39
    Aug 2014
    yes
