Page 1 of 4 1234 LastLast
Results 1 to 13 of 48
    Aug 2014
    getting high head pressure issue
    hello techs, I worked on a york 15 ton 2 stage split unit,condensing unit shutting off on high head pressure,after monitoring operation am getting 52degree subcooling seems like over charge but it's not cause my comp amps are below rated,also my suction pipe by the condensor is freezing, & not by the airhandler any idea what could be wrong I think it's a clogged drier? any directions would help I will provide unit nameplate & pressure, temp reading. thanks
    york M#H4CE180A25A
    S# (S)NOK6893108
    R22
    lowside: 50psi
    highside: 330psi slowly rising
    suction pipe temp 35
    liquid pipe temp 88
    O.D temp 94°
    S.A 55-54
    R.A 70
    Aug 2009
    Prattville, Alabama
    Your liquid line temp is 6 degrees cooler than your outdoor temp.
    Aug 2014
    to help with the headpressure issue, i washed down the condensor coil but seems like other issue my opinion is filter drier
    SE Pennsylvania
    By the fact that suction line is freezing by the condenser I would think severely overcharged due to restriction, low airflow or both.
  5. Likes JeffWil liked this post.
  6. #5
    Jun 2018
    Ct.
    a clogged dryer is easy enough to diagnose. measure LL temp before and after. shouldnt have much of a difference
  7. #6
    Mar 2013
    Billington Heights, NY
    sounds like a restriction before the LL service valve. Is there an internal drier?
  8. #7
    Aug 2014
    your correct I take that back,drier is not the issue,I figured it out its low air flow,due to poor duct design from day one this was new job for me so I had to look into all this,thanks for looking in to my post
  9. #8
    Aug 2014
    the problem is with air flow I spent time & analyzed the system, other then that they didn't install traps on suction pipe 1 1/8 rising above 50ft,no oil separator,its a mixer of problems
  10. #9
    Aug 2014
    its air flow issue
  11. #10
    Mar 2013
    low, even NO air flow, isnt going to cause the symptoms you have.
  12. Likes BALloyd, JeffWil liked this post.
  13. #11
    Southold, NY
    How does Low evaporator air flow give you High Head Pressure?
  14. #12
    Mar 2015
    Medford, N.Y.
    94*F ambient gives you around a 125* SCT & that is around a 275psi head press.
  15. #13
    Mar 2013
    Treasure coast, FL
    "hmm this suction pressure is awfully low... Better add some more refrigerant."
    Sent from my Moto Z (2) using Tapatalk
  16. Likes Core_d liked this post.
