Results 14 to 20 of 20
    Mar 2010
    Houston
    Quote Originally Posted by Zamoramax View Post
    Just throwing this out there. My local mitsh rep has flat out said NO to nylog. I have still used it from time to time but I try to stick with POE or PVE.
    The 2nd is there to protect the 1st. DTOM
    OFF TOPIC ALERT
    Just had Mitsubishi Tech support tell me, in writing, that they specify a:
    - 600 psi leak test for minimum of 24 hrs,
    - then triple evac,
    - two hour below 500microns,
    - then a 1 hr rise assessment.
    He sent me this in writing. I am officially whining to their engineering dept to reconsider as this makes no sense for a new 1-2 ton resi install. It turns every sale into a two-day install...that should impact sales or every install will not be to spec. On a complex Multi-branch setup, ok, I get it, but not a one to one mini-split.
  2. Likes joemach liked this post.
  3. #15
    Oct 2014
    Columbus, Ohio
    Quote Originally Posted by KeyResults View Post
    — OFF TOPIC ALERT —
    - then triple evac,
    Look at it this way, it makes warranty calls for refrigeration problems disappear, until the evap starts leaking.
  4. #16
    May 2013
    I've been in a Mitsubishi class that has said Nylog is ok. I also did a Fujitsu class that said Nylog is ok. I also wonder why your rep said no to it?
    Sent from my SM-G903W using Tapatalk
  5. #17
    Feb 2018
    Bay Area, Ca
    Quote Originally Posted by joemach View Post
    Did he explain why, "No Nylog"?
    His exact words were"that stuff always gets into the system and finds a LEV". Maybe he's seen it where some jackwagons use 1/2 the bottle on a flare...
  6. #18
    May 2014
    O.C., Ca.
    I use the bottles that my contact lens cleaner comes in, two different sizes, one has a screw on cap & the other has a snap top cap. Never had a leaking problem.
    I keep ref. oil, rust buster & a light lubricating oil in them. Works great!
  7. Likes rjk_cmh liked this post.
  8. #19
    State College, PA
    That is what I was thinking. But Nylog is just refer oil as far as I know.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
  9. #20
    State College, PA
    — OFF TOPIC ALERT —
    - then triple evac,
    I can almost guarantee that no one does it that way. I worked for a Diamond Dealer and that was never done.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
