Results 1 to 13 of 28
    May 2009
    SC
    Daikin intelligent Touch Manager
    Our favorite VRF company is back at it and seems to have an all new BACnet/IP product, new to me but been around a while. This Daikin intelligent Touch Manager has a color touch screen and reminds me of what Mitsubishi has had out for some time now. http://www.daikinac.com/content/comm...touch-manager/
    "Special" things I've encountered with this after working with it for one day:
    • The setpoint are not behaving right. Start with a cooling of 74 and heating of 70 with a "Min Setpoint Differential (Cooling & Heating)" of 2. If I write a heating setpoint of 68 the heating setpoint changes AND the cooling setpoint changes to 70, ignoring the previously written 74. If I then write a cooling 74 the heating will then change to 72. Seems like Daikin invented a whole new definition of "minimum", or the point description of "Min Setpoint Differential (Cooling & Heating)" is wrong and we need to know what that means. I could understand an enforced minimum setpoint separation but that is not what this is behaving like.
    • In BACnet discovery I don't see an obvious ON/OFF command point for the IDUs. The marketing cut sheet says there is one, and it has a status point for it. Nothing showed up in discovery that I'm seeing though. http://www.daikinac.com/content/asse...PF-iTMSERV.pdf
    • No idea what point description Thermo-on Status is. There is also an override for it.
    In general we are communicating with the unit and can do some things but need these and possibly other questions answered. We will be reaching out to Daikin but if anyone knows anything about these please let me know, thanks.
    Some odds and ends; ITM is a ROUTER and generates a network segment below it. Everything including the system panel will show under that network as individual devices which is rather nice. Even better the equipment names will come through in BACnet discovery. I assume there is some special software necessary to change device instances and network number as they can't seem to be changed on the screen? I haven't investigated this yet.
    IDU discovered points, I find it mildly interesting that ALL points are numbered sequentially, regardless of type. Never seen that before. I haven't yet found a difference in points depending on different IDU types, for example if it isn't capable of airflow direction it will still have the point.
    Code:
    Analog Input-5 Room Temperature
    Analog Value-10 Max Cooling Setpoint
    Analog Value-11 Min Cooling Setpoint
    Analog Value-12 Max Heating Setpoint
    Analog Value-13 Min Heating Setpoint
    Analog Value-14 Min Setpoint Differential (Cooling & Heating)
    Analog Value-6 Occ Cooling Setpoint
    Analog Value-7 Occ Heating Setpoint
    Analog Value-8 Unocc Cooling Setpoint
    Analog Value-9 Unocc Heating Setpoint
    Binary Input-2 Unit On_Off Status
    Binary Input-23 Filter Sign Status
    Binary Input-25 Indoor Fan Status
    Binary Input-26 Communication Status
    Binary Input-27 Thermo-on Status
    Binary Input-29 Aux Heater Status
    Binary Input-3 Alarm Status
    Binary Input-31 Indoor Unit Changeover Option
    Binary Value-15 Cooling & Heating Setpoint Tracking Mode
    Binary Value-18 Timed Override Operation
    Binary Value-21 Remote Controller Prohibit (Operation Mode)
    Binary Value-22 Remote Controller Prohibit (Setpoint)
    Binary Value-24 Filter Sign Reset
    Binary Value-30 Forced Thermo-off
    Multistate Input-19 Current Unit Operation
    Multistate Input-28 Compressor Status
    Multistate Output-1 Occupancy Mode
    Multistate Value-16 Fan Speed
    Multistate Value-17 Airflow Direction
    Multistate Value-20 Remote Controller Prohibit (On_Off)
    Multistate Value-4 Operation Mode
    The key value pair for airflow direction is meaningless to me, everything else contains values that make plain sense.
    Code:
    Keys	Values
    1	P0
    2	P1
    3	P2
    4	P3
    5	P4
    6	Reserved
    7	Reserved
    8	P7
    Scott Jalbert, WebCTRL ninja, Naiagara AX and Smartstruxure newb, SiteScan Retired
    The master has failed more times than the beginner has even tried
    Dec 2006
    What? Who? Where?
    Appreciate the heads up. Asia has some interesting implementation of BACnet and controls standards / language / descriptions.
    kontrol out
    "Good" - Jocko
    "Open is as open does." - Forrest Gump
    "Can't we all just get a Lon?" - Garry Jack
    "BACnet: integration or interrogation?" - The Janitor
    "Interoperability? You can't handle interoperability!" - Nathan R. Jessup
    “What’s that? Aaa… open protocols? Don’t talk about…. open protocols? Are you kidding me? Open protocols? I just hope we can hardwire an interface!” - Jim Mora Watch it here!
    Feb 2005
    Thermo-on Status
    I believe this indicates if IDU is presently and actively either heating or cooling
    Forced Thermo-off
    I believe this is like forcing a fan only mode and disabling both heating and cooling of that IDU
    good luck.
    Jan 2003
    Quote Originally Posted by MaxBurn View Post
    Wonder if that enables/disables that behavior.
    May 2009
    SC
    Quote Originally Posted by amigo View Post
    Thermo-on Status
    Forced Thermo-off
    good luck.
    Should be easy to test, thanks.
    Quote Originally Posted by orion242 View Post
    Might not be a coincidence that point is reporting ON at the moment. Good idea.
    May 2009
    SC
    Just remembered one other little odd thing about this system. The setpoint limit and differential points are marked out of service by default. For some strange reason I wasn't able to programatically write OFF to bacnet://deviceid/av:14/out_of_service, I got errors like write access denied etc in my program. I was able to go into our discovered points and turn them off there, which kept the new guy busy for a half hour or so. Might be an ALC issue but I've done that for Trane before and worked fine there.
    I do like the concept of having hard limits on setpoint range in the Daikin BACnet as it eliminates a common request we get for VRF systems; we need a setpoint adjustment limit. Before this could only be done locally in each stat is my understanding, not remotely. Before we would have a valid range and if a user went out of bounds we would bump them back to whatever was allowed. That was confusing for the occupant because the stat literally changed behind their back. I'm assuming this new limit will show up on the stat, but need to test that.
    Jan 2003
    and the $50k question...
    Does it stay online for more than a week without a power cycle?
  8. Likes stanbyyourword liked this post
  9. #8
    May 2009
    SC
    Well so far haven't caught it down. This is an active construction site in a new building so I'm expecting problems. I stuck a LTE modem out there along with putting the site in our hosting environment so the system is very isolated, realistically just the two devices but I can work on it any time I want. That is just plain working and seems a regular medium building is going to use 500mb a month in data. More reliable and using less data than I anticipated.
  10. #9
    Feb 2005
    What is this? Is it home brew or a commercial solution?
  11. #10
    May 2009
    SC
    Home brew. Centers around some VM's we put in our data center rack space and OpenVPN/Ubiquiti routers to pull it together.
  12. #11
    Feb 2005
    okay, sounds like fun,
  13. #12
    Jan 2003
    Home brew
    Not hipster enough. Microbrew infused with blockchain technology.
  14. #13
    May 2009
    SC
    It's an artisanal tenant entertainer where the best work of Diffie and Hellman connect you to the darkest reaches of your gig space for an executive solution.
