Page 9 of 10 FirstFirst ... 2345678910 LastLast
Results 105 to 117 of 128
  1. #105
    Jul 2018
    SeaTac WA
    I have seen old ass Maneurope GE compressors outlive everything else on the unit. 30 years once from the 60s and 70s
    Sent from my SM-J700T using Tapatalk
  2. #106
    Jul 2018
    SeaTac WA
    Compressor manufacturers overall have been experiencing more compressor failures with the new p o e oil. I've learned this at a Copeland seminar, the p o e oil will eventually evaporate off the internal compressor parts if the compressor doesn't run for over 24 hours. They get dry starts. It's just not nearly as good as the mineral oil
  3. #107
    Jun 2011
    NE Ohio
    Quote Originally Posted by thekux View Post
    After it passes a pressure test I know and a half an hour with a 7 CFM vacuum pump is going to be ready to go a smaller system.
    it is ready when it is ready, and the only way you can know is by using a micron gauge, PERIOD .... ( or a triple evacuation but we dont need to go there )
    .... if the system was flat and is moisture ridden it will take longer than a half hour ... there are also other reasons it will take longer ....
    you can do whatever you want and I surely am not nor do I care to speak for anyone else but I imagine few other people care what you do either, imagine the reason most of us our out here is to try and step up our HVACR game ... but as mentioned there is a right way and a wrong way ...
    try and keep an open mind ... PEACE
  4. Likes thekux liked this post
  5. #108
    Jul 2018
    SeaTac WA
    Quote Originally Posted by hvacskills View Post
    .... if the system was flat and is moisture ridden it will take longer than a half hour ... there are also reasons it will take longer ....
    you can do whatever you want and I surely am not nor do I care to speak for anyone else but I imagine nobody else cares what you do either at all ... but as mentioned there is a right way and a wrong way ...
    I have an open mind but I have given my examples too. But if the boss is willing to pay for a triple evacuation on it unit hey what the hell go get yourself a coffee
  6. Likes hvacskills liked this post
  7. #109
    Jul 2018
    SeaTac WA
    A couple of evaporator Replacements coming up maybe I'll have the school district bounce for micro gauge and just see for fun.
  8. Likes hvacskills liked this post
  9. #110
    Jun 2011
    NE Ohio
    be sure and use 2 VCRs and 1 /2 " hoses or you will be spinning your wheels .... plenty of threads no here the best way to go .....
    and listen to this podcast if you get a chance, good stuff ...
    https://www.youtube.com/watch?v=03QPUIyPkT4
  10. #111
    May 2013
    You don't have your own micron gauge for all your sidework?
  11. Likes HVAC_Marc liked this post
  12. #112
    Jan 2010
    Sea to Sky
    Can anybody tell me why a system that held 400 PSI either 7 or 10 ton system would not hold 500 microns? Wouldn't drop 1 psi couldn't hold 500 microns leak detector couldn't detect anything
    Because your evacuation setup is likely f#$@@^÷.
    Sent from my SM-N910W8 using Tapatalk
  13. #113
    Mar 2013
    Billington Heights, NY
    Quote Originally Posted by Lahrs View Post
    He just purges the line set with the refrigerant of the day.
    I read all these recent posts and I gotta say Metalman's post says it all... I wish I could like it a thousand times!
    Really, Ben, stop telling people where you work, how you violate your local laws, and what codes you break without a worry in the world. You do realize that it's more than just techs on this site, right? There's law enforcement, code officers, OEMs, Reps, and likely your employer. Plus, if you piss off someone just enough they may even take the effort to print out all the pertinent stuff here to get you into major trouble! All it takes is a certified letter. Just STOP talking.
  14. Likes JeffWil liked this post
  15. #114
    Jul 2018
    Ohio
    Quote Originally Posted by HVAC_Marc View Post
    It's only one call away.
    I said my piece, and got wound up about it, but there is nothing you can do if he won't listen to reason, continuing to converse with him and the comments get worse and worse, he leaves more of a trail of poor information on here in an open forum where people can read his unsuccessful successes and apprentices, young techs, and prospective clients, could be swayed by his incomprehensible shoveling loads of horse and possibly believe anything he says.
    Some times a pimple that won't pop is best left alone.
    Sent from my XT1710-02 using Tapatalk
  16. Likes HVAC_Marc liked this post
  17. #115
    Southeastern Pa
    Maybe we can tempt Pony to come back.... I enjoyed being a "grump."
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  18. Likes HVAC_Marc liked this post
  19. #116
    Jul 2018
    SeaTac WA
    What do you think?
  20. #117
    Jul 2018
    SeaTac WA
    Now all of you got me thinking how about this megaflow manifold it's supposed to be 16 times volume increase for pulling in a vacuum anyone have experience with this?
    http://www.appioninc.com/products/mgamanfeatures.htmlw
