+ Reply to Thread
Page 4 of 4 FirstFirst 1234
Results 61 to 77 of 77
Thread: Leak Checking Low Pressure Chiller CVHE
  1. #61
    Aug 2009
    Prattville, Alabama
    Quote Originally Posted by WYLBEK View Post
    Is that for real, tell me that's just a joke!
    Sent from my SM-G950U using Tapatalk
    I was told this by my service manager early in my career. About 33 years ago. A customer's maintenance staff did this, sometime in the past.
  2. #62
    Aug 2009
    Prattville, Alabama
    I think I remember Healey having a similar occurrence in his area.
  3. #63
    Jul 2018
    Ohio
    Well that's really lettin the magic smoke out there
    Sent from my XT1710-02 using Tapatalk
  4. Likes Nuclrchiller liked this post.
  5. #64
    ottawa canada
    Quote Originally Posted by Nuclrchiller View Post
    You are correct . I was told by an old timer Trane guy that they had a propane fork lift hooked up to the back of the motor and were trying to yank the sucker out without going in the front end first . Chiller ended up in the dump , and the fork lift needed new tires
    I"m not a service tech, I’m retired ….I used to be a thermodynamic transfer analyst & strategic system sustainability specialist
  6. Likes Nuclrchiller liked this post.
  7. #65
    Apr 2017
    The Deep South
    Quote Originally Posted by Healey Nut View Post
    That is NUTS!!!! You just can't fix stupid.
  8. #66
    Jul 2003
    Reminds me of the days of leak checking r113 chillers low on charges, sometimes you’ll be lucky to hit 2psi. That’s circulating hot water 130 degrees.
  9. #67
    Aug 2009
    Prattville, Alabama
    Quote Originally Posted by chillerguru View Post
    Those days were so far back for us that we used Nitrogen, lol!
  10. #68
    May 2017
    Step away from the chiller 😂😂
  11. #69
    Dec 2018
    when circulating your water make sure it's vented so it does not pressurize
  12. #70
    Mar 2019
    Ever heard of Prevac?
    Quote Originally Posted by SanchezHVAC View Post
    I am trying to leak check a Trane CVHE (low side leak) I started by draining the evaporator barrel. Valved off water in water out. I filled evaporator barrel with 114°F water. I still can't get my pressure up passed 0 psig. So I drained the Condenser and also filled it with 114°F water. The UCP is reading 2 psig, but my gauge that is hooked to the evaporator is still reading 0. Another thing that is confusing me is I still have liquid refrigerant coming out the top of the evaporator.
    I'm sure you figured out this problem by now, but are you aware of the product PREVAC that prevents air and moisture from entering the chiller when idle? It also has push button leak testing for servicing. Want me to send you some information?
  13. #71
    Apr 2011
    Southern Indiana
    Quote Originally Posted by PREVAC View Post
    Yea this job is complete. Yea go ahead and send me that info, it never hurts to get new info.
  14. #72
    up in the hizzy
    Do you work for prevac? I have questions about the pressure transducer for r123, whats the output? 0 to 5V, 4 to 20...? and whats the pressure range? thanks
    There is not better place for the working men than the union! 100% UA the only HVAC union!
  15. #73
    Mar 2019
    Quote Originally Posted by valdelocc View Post
    Yes I do. The output on the pressure transducer is 4-20 milliamps. The pressure range is 30" of vacuum (-15 psig) to 15 psig. Do you do a lot of work with low pressure chillers?
  16. #74
    up in the hizzy
    Thanks! I work on low pressure machines here and there.
    I removed a PreVac setup from a decommissioned chiller and I going to mount it on a hand cart, make it portable and use it for leak checking, the only thing missing was the transducer.
  17. #75
    Mar 2019
    Does it have a 4 wire connection or a 2 wire connection for the pressure transducer?
  18. #76
    Feb 2017
    Australia
    BennyD
    You should have gone with your gut.
    Potentially 90 % of leaks are found on either economizer flange at bottom of evap or suction elbow to evap due to rust etc
    Sent from my SM-G965F using Tapatalk
  19. #77
    Feb 2017
    New York
    Quote Originally Posted by brett2008 View Post
    BennyD
    I know......
    -----Stop, step back, relax and have another go at it.-----
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
