Results 1 to 7 of 7
Thread: Is it okay to remove this from the DIY finished basement the prior owner added in
    Jul 2018
    Question Is it okay to remove this from the DIY finished basement the prior owner added in
    Hello,
    Just bought a house with a partially finished basement in it.
    Basement is rectangular shaped, with the finished portion taking up an 'L' portion of the space, and the unfinished side (where the heat pump and air system is located) taking up the remaining square portion of the rectangle.
    The basement has 3 vents, 2 that are output vents and 1 that is an input (suction) vent. I curious if it would be okay to take out these 2 input vents?
    The site doesn't allow me to post images lol (rules are awesome). But on the unfinished portion, they added this jerry rigged setup feeding 2 flexible shafts (made of plastic bag-like material) to the 2 output vents and duct tape. I'm just not sure if there would be issues taking out these shafts to free up the corner of the unfinished portion of the space.
    Thanks for any help!
    Mar 2009
    Mount Holly, NC
    Your question is confusing.
    You said two output (supply) vents, and one input (return) vent... but you want to move the two input (return) vents...
    Exactly what do you want to do?
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Click below to BECOME a pro member
    https://hvac-talk.com/vbb/forumdispl...ip-Information
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
    Houston,Texas
    Quote Originally Posted by discovermypath View Post
    jerry rigged.
    Down south, we use a less politically correct term....
    “Experience is a hard teacher because she gives the test first, the lesson afterwards" ~ Vernon Law
    "It's what you learn after you know it all that counts." ~ John Wooden
    "When the teachers become unteachable we're all in trouble" ~ Mr. Bill
    "Remember "Pro" is only a name, it's not always a mindset determined to do everything correctly" ~ Mr. Bill
    Jul 2018
    haha awesome! definitely not the terms I used when I noticed the setup and happy there are still some folk who don't care so much about political correctness.
    Jul 2018
    sorry for the confusion. I wrote the post with the images at first, but then it wouldn't let me post with images so I had to go back and reword everything.
    So I want to remove and seal off the output (supply) vents, leaving 1 return vent in the basement.
    Mar 2009
    Mount Holly, NC
    No.
    Either leave at least one supply, or seal everything...
    But it may impact your system function.
    I am yourmrfixit
    Mar 2013
    East Concord, NY
    If you leave no supply vents in the cellar area it will create a negative pressure there. What will happen is that it will pull air from any other positive area - leaky ducts, the outdoors, the upstairs, etc.
    If that's what you are trying to achieve, then do it.
    Nest is POO!!
Quick Reply Quick Reply
Register Now
Log-in
Tags for this Thread
  • You may post new threads
  • You may post replies
