    Jul 2018
    Post More Efficient Thermal Energy Exchanger Device(Heat Pipe)
    Hi everyone,
    Heat pipe is device that transfers heat using the principles of both thermal conductivity & phase transition so that heat can transfer effectively between two interfaces.Heat pipe is a self-contained passive energy recovery device.
    heat pipe heat exchanger can recover up to 85% of exhausted thermal energy. However under ideal conditions the thermal efficiency of an economic system ranges between 55 to 70% and saves millions of BTUs year after year.
    Anybody knows more information regarding Heat Pipe Please let me know?
    Thanks ,
    Kaadhira
    Are you interesting in building heat pipes?
    For solar energy they are pretty simple. Of course heat pipes require a working fluid with a boiling point / condensing point about midway between the two working extremes.
    For solar heating of water I use acetone.
    What is your application? What are you looking to absorb heat from? What are you looking to add heat to?
    PHM
    Quote Originally Posted by Kaadhira View Post
    Hi everyone,
    Thanks ,
    Kaadhira
    PHM
    Mar 2013
    Billington Heights, NY
    CPU coolers use heat pipes as primary heat transfer devices. The OEM would be able to tell you how they work and then you could model it on a larger scale with less primitive application.
    Oct 2014
    Columbus, Ohio
    The most common use of a "heat pipe" (i.e., a phase change device with no compressor) is in the MiTek dehumidification coil. It heats up on one side and cools down on the other to aid in dehumidification, and is powered by fan energy. I don't know how often they are actually used in industry - most engineers would specify something like a heat wheel or ERV/HRV core instead. But the heat pipe solution doesn't require exhaust air to work.
    I've often considered using a small heat pump to do energy recovery between intake and exhaust ducts that are too far away from each other to use a heat wheel, but haven't ever had the time to sit down and figure out how well it might work in practice.
    Jan 2015
    East Tenn
    Why so Far away from Each Other I seen them - side by Side to take Advantage of Heat Transfer _ Just have to Place Exhaust 3 ft Higher or Lower
    Then the Intake Stack - that said - 90 Degree Elbow on 1 - Other Gets - 45 Degree then short 12 inches or so straight pc. and another 45 Degree Degree in Opposite Direction .
    ( Just for some Separation Distance ) and to Direct . .
