Results 14 to 17 of 17
    Jul 2018
    SeaTac WA
    Many times I've seen the breaker that feeds the condensing unit not at Max fuse size. That's the first place to go inspect the contactor for it looks a little beat up replace it and if it's a single phase put a good start kid in it even if you have to get from the supply house to get the manufacturer start assist or a Supco.
    Sent from my SM-J700T using Tapatalk
  2. Likes Raehvac liked this post
  3. #15
    Jan 2017
    San Diego
    Quote Originally Posted by Answer-Man View Post
    3 ton York Pulling 70+ amps (LRA). What is the breaker rated at 20 or 30 amps?
    I believe about all manufactures state the voltage can be +/- 10% and not effect operation
    I understand the whole "inrush" starting amps therory, but rarely do most units pull the rated LRA, because most units don't operate at the ARI rated conditions. I would be looking for a defect like: at the contactor, connections (don't forget the connections on the copressor), condensor fan and capacitor. Understand your problem before you start adding stuff that may hide the real problem and have it fail a short time later.
    Good Luck
    It was the contractor.
    Sent from my LG-TP450 using Tapatalk
  4. #16
    Southeastern Pa
    Quote Originally Posted by Raehvac View Post
    Well at least you're honest.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  5. #17
    Jan 2017
    San Diego
    Haha Freudian slip!
