Results 1 to 6 of 6
Thread: IoT gauges
    Jul 2018
    Central Florida
    IoT gauges
    I made my own always-on A/C monitoring system which reports the PT's to the cloud where I can go view graphs from all time.
    Here is the setup from bottom up
    DS18S20 temp sensor & refrigeration tape
    0-5V, 0-500 psi pressure transducer, Digikey
    Custom PCB
    ESP8266
    NodeMCU LUA code
    Thingspeak.com
    All A/C's should send their information to the cloud. A system like this either factory installed or service company installed would be great. We could sell monitoring for a $2/mo fee and predict when the system will need servicing. The Internet service would (on the tech's end) detect certain problems before they are major in a way that only an always-on system could: tiny leaks, TX valve sticking, partial clogs, minor compressor wear. Then reach out to the home owner and offer service as a reduced cost for them to avoid major service.
    Dec 2012
    columbus, OH
    Cool, got pics?
    Nov 2011
    East Side
    I know a company that was developing this exact system....checked in to the home base, messaged contractor and or homeowner with problems, etc. etc. they got half through the development stage and the Money backed out. shame really, they could have made millions with it.
    Oct 2018
    Washington
    Yeah...it is very interesting to look at it...are there any pics?
    Oct 2011
    Chicagoland Area
    Why reinvent the wheel?
    Pelican Wireless and Honeywell LCBS and Prolon are already doing it on the commercial end with temperature and energy data going to the cloud. While they don't monitor pressures you could use a pressure switch wired in to a set of dry contacts that would trigger an alarm which then could be emailed or texted to the service company and/or homeowner. Pelican is the most user friendly of the 3
    weber's Avatar
    weber is offline Professional Member/Membership Committee
    Southern Ca, Elkton Md
    In the 90's we had this product that would tie into your phone line, in the mid 2000's we developed one that connects to wifi. Today I have a cell based monitoring system. Pressures, temps, amps, SH & SC, flood protection, water usage, and a predictive breakdown algorithm. Along with much more.
    If you're interested in learning more about the product or how to incorporate it into your business model let me know.
    "Correct Installation is the Key"
    .1 has killed more HX then Rush Limbaugh
    What is your TESP?
