Results 14 to 26 of 41
    Jul 2018
    Bay Area, California
    @Bbeerme, I am having a humidity issue in my walk-in, seeing if I could pick your mind, since we are both in the bay area.
    Mar 2013
    Billington Heights, NY
    Quote Originally Posted by Cooler_Newbie View Post
    I sense another DR thread coming up!
    Caledonia WI
    Did he at least offer to do the other hand right away so you'd have a matched set?
    Hope it heals up quick for you.
    Quote Originally Posted by rjk_cmh View Post
    Sure did, and also learned to always keep both hands on the drill, in this case I was holding the board while someone else was drilling, which was a big mistake.
    It's not what you're capable of doing that defines you, it's what you do on a daily basis.
    Jul 2001
    Fairfield and NewHaven Counties in Commecticut
    Thought I was going to be all fancy and bend everything - worked fine for the 7/8 (maybe a little wrinkly on the 90s), but one of the 1-1/8 bends looks like this
    Attachment 800991
    I guess I'll have to just pressure test it and hope for the best.
    Need to braze over that kink
    Sent from my Pixel XL using Tapatalk
    Quality and Value Service and Repair
    Oct 2014
    Columbus, Ohio
    Quote Originally Posted by Freezeking2000 View Post
    So just heat it up and drip some braze rod on it? I was going to pressure test at 450 psi and hope for the best. Maybe I could drop on some staybright #8 since it's up in the attic and I'm trying to avoid too much hot work up there.
    This damn bender has some design flaws I think.
  6. Likes DavidDeBord liked this post.
  7. #19
    May 2014
    Bay Area California
    Sure. You can try. Be advised though, you'll be in competition with all of the beer I've been drinking through the years.
    Unless you've got something like flowers, the usual complaint is too humid. If that is your case, longer run times is the simple fix. If it is some sort of critical application, then adding heat strips is the usual solution.
    I do a triple evac with nitro to remove non condensables.
  8. Likes DavidDeBord liked this post.
  9. #20
    Mar 2015
    Hamersville, Ohio
    Well, it was a hole saw accident where the pilot bit wasn't set out far enough, and the wood we were drilling into wasn't held down too well. The drill caught and jumped out and bit me, 9 stitches.
    Looks like you'll be able to keep your thumb nail.
    Did you "Learn Anything" Rjk-? I'm Kidding & hope You get full usage of your hand soon.
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your God’s law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    Mat_15:24 But he answered, “I wasn’t sent to anyone but the lost sheep of the house of Israel.”
  10. #21
    Mar 2015
    Hamersville, Ohio
    Quote Originally Posted by HVAC_Marc View Post
    Dont feel too bad. I always forget to look behind what im drilling. I once severed an electrical line for a living room. The second time I cut open a live 1/2" water line
    If You had brought yer ladder, ... You might of caught those Lil' items.
  11. Likes HVAC_Marc liked this post.
  12. #22
    Mar 2013
    Quote Originally Posted by DavidDeBord View Post
    I already asked that in post #7... geez, you're slow in your old age
    Ladders dont talk to me.
  13. Likes DavidDeBord liked this post.
  14. #23
    Mar 2015
    Hamersville, Ohio
    My Apologies, .... I often have to grab a baseball bat, & Stoutly thunk my head several times to beat back the Dementia.
    "Ladders dont talk to me. "
    Well done! By speaking of it in the plural, You've side-stepped the statement regarding your "relationship" with Yer "Ladder".
    Back in th' Day, .... I used to be able to walk up to equipment & it would "Speak to Me", & tell me what it's problems were, ... Never had to pull out any testers or gauges.
    But then I ate some GMO Food, & that Ability disappeared.
  15. Likes HVAC_Marc liked this post.
  16. #24
    Oct 2014
    Columbus, Ohio
    The attic in this place isn't too bad, big enough for me to stand straight up in, but the joists are 4 feet on center so you have to be really careful.
    The tinners have been doing a nice job.
    I was able to finish connecting one outdoor unit today and it's holding 450 PSI with no leaks so far.
    Still need to fasten the sealtite to the wall so it isn't flapping around.
  17. Likes DavidDeBord, HVAC_Marc liked this post.
  18. #25
    Mar 2015
    Hamersville, Ohio
    Is that room for the Equipment part of the Attic Rjk?
    hey! Take some of that Hard Earned $$$$ & Buy yourself a New Pair of Boots.
    The installation looks Outstanding!
  19. #26
    Oct 2014
    Columbus, Ohio
    It's a mezzanine that we built as a mechanical room, the attic is above it. The ceilings in this place are 15'6" and we put the mezzanine above the bathrooms. It has 6' of space so I can stand up without crouching.
    We're all volunteering on this project on Saturdays so there's no $$$, just a nice new school for our kids.
  20. Likes DavidDeBord, BBeerme, HVAC_Marc liked this post.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
