Page 32 of 32 FirstFirst ... 222526272829303132
Results 404 to 413 of 413
  1. #404
    May 2014
    Bay Area California
    DR BBeerme
    Quote Originally Posted by Mike19 View Post
    We should get Dad to change our usernames.
    itsiceguru
    MikeGuru
  2. #405
    Nov 2014
    Chicago Illinois
    Yeah I almost always purge the system with nitrogen but have don’t plenty with a nice long vacuum only with the same results and I ain’t no hack.
  3. #406
    Quote Originally Posted by OGlad View Post
    suppose you do your brazing and shoot 200 psig through high side with an open shredder on suction line. Wouldn't the oxidation exit through the open valve?
    No
  4. #407
    itsiceguru
    MikeGuru
    MTHuru
  5. #408
    Quote Originally Posted by heatingman View Post
    Do you have a picture/sketch of what your talking about?
    Very curious about this.
    Maybe
  6. #409
    Oct 2012
    Where we mow our own grass
    MTHuru
    fkn rights eh
  7. Likes Jettinvr6sc liked this post
  8. #410
    Sep 2018
    San Diego
    Quote Originally Posted by HVAC_Marc View Post
    Not following the OEM's guidelines during an installation or repair makes you a hack.
    I'll leave it at that.
    Then you must always also always triple evac too???
  9. #411
    Sep 2018
    San Diego
    Just wait...you'll see. It just hasnt bitten you yet.
    I don't agree. I have been in the trade since '78. In the early years we did not braze, we used 95/5...so many less leaks and never overheated valves etc...
    When I braze I rarely use 5% I prefer the 15% and I only braze it until it seals, it's that glowing red pipe that causes the oxidation and I don't heat the pipe to that point, purposefully. At the indoor coil I also prefer silver solder (6%) because it is much faster, seals evenly and the piping doesn't have to get as hot. Working this way I rarely have leaks to keep working on. Honestly, I can't recall the last time I discovered a leaking connection during the pressure test.
    I have only had two incidents with TXV's and both were on change outs from 22 to 410a, both caused by clogging from the oil mixture (I assume the flush was not done well enough). Our flushing procedure got better and we also use super change to neutralize. Where possible we also change out the line sets.
  10. #412
    Sep 2018
    San Diego
    Quote Originally Posted by hvac1993 View Post
    Thanks for posting.
    I have had similar findings.. This is pretty much why I started the thread.
    The oxide builds up when the pipe glows red. That is what I was taught some 40 yrs ago. many techs have trouble getting some particular joints to braze up...In my opinion the pipe wasn't cleaned well enough to start with and they keep heating up the joint and adding more silPhos...
  11. Likes lions_lair liked this post
  12. #413
    Mar 2013
    Port St. Lucie, Fl
    Quote Originally Posted by yassine View Post
    The sky is falling
    Thanks, chicken little.
    Sent from my Moto Z (2) using Tapatalk
