Results 1 to 4 of 4
    Jan 2015
    East Tenn
    Cool Few Sheet Metal Shops - that do Hospitals
    (( Few Sheet Metal Shops - that do Hospitals and the Like ( That do Duct Work )) Will Generally Sit Down with You , Bring Donuts . .
    Give then the Dimensions You need and They will Bend Up - Your Returns and Get Std Size Filter Housing Attachment Face Plate . .
    2-3 Pcs If that's a enough Duct work - get close to Equipment about $-$ .. 22 Gauge . .
    Oct 2014
    Saint Pail, Minnesota
    Ill have whatever drugs you are on because you are not making any sense. If you are advertising, you’re doing it incorrectly on this forum. And if it is advertising you are also bad at t.
    Jan 2015
    East Tenn
    OK, Fear Enough I wasn't Very Clear . . For all You NON Union - Get It Done Contractors Making a Living doing Excellent Work or DIY Guys & Gals
    U Probably don't have Duct Work Maker in Your Back Yard . . and ( That don't Have Sheet Metal Bender ( Machine ) or Brake etc.
    @ Their Access . .
    Might want to check out Duct Work Suppliers around that do Larger Semi Commercial work like Hospitals , as they Buy Sheet Metal in Huge Volumes - I have Found Sheet Prices to way Lower ..
    Custom Sizes etc. made to Your Spec's - By Sitting Down - Meeting Lay Out Guy . . They usually are very Helpful - won't Cost $ a Pc . ( 22 Ga. ) as there is Nothing Standard about these Older Homes ..
    So - LOL - Thanks for the Bump
    Looks lie your trying to promote DIY.
    Thread closed.
