    Jan 2015
    East Tenn
    Mini Splits - I Have Min. Experance with These , Few Basic ?_? 's
    Min Splits - Gree vs Mitsubishi vs Bosch anyone anything ?
    Sec. anyone see or seen or done Wall Mounts ?
    Looking at Possible Above Porch 4/12 Pitch Large Walk-able Area . . wondering about Sound Vibration and Strength Needed ?
    Have Brick / Over Stick . .
    Line Sets ? Is this a Special Copper ? or just some Half Hard Coil Stock ?
    I have seen the Special Extra Thick Insulated , Special Easy Slide Over on Extra Thick Insulation ones $200-300.00 Ouch . .
    Next Up there is the Protection of those Lines Sets as they Travel to Main Unit , ( Any Nice Covers ) Keep IR / Ultra Violet Rays in Check . .
    Thinking Large Gray ( PVC Electrical Conduit ) Type Pipe for Super Protection _ maybe Over Kill . . .
    Jan 2015
    East Tenn
    Not Even some Photo's of What Good Install Looks Like ?
    Line Protection ?
    I Guess they don't even Know about the Copper their Using . . ZZzzzzz
    Go to the Wall of Fame, there's some pretty sharp jobs there. We did a Mitsu Hyper Heat today, man those things are quiet.
    Jan 2015
    East Tenn
    OK , Will Do !
    I have been Checking - Lines Out
    Checking up on Compression Fittings
    Checking on Copper Required
    Flare Tool .
    Sealer ( Yes or No ) ? on Flare . . . some use Refrigerant Oil ?
    Will Use a Tq. Spec. Tool - Even Thou My Hands Know what 40-55 is and 65-84 ft. Lbs are ..
    Just for Laughs Thou Guys - Wet Tq. is Not the Same as Dry Tq. - when it comes to Ft. Lbs , so ( Careful )
    Jan 2015
    East Tenn
    PS : Choosing Ground Location , Have a Half Wall 2.5 - 3 ft. where it would sit real nice and Fit under the Railing . .
    Will have 1 Longer Line set ..so Hoping to get all the Details for Rough _ In Worked Out . . Later in Week ..
    Jan 2015
    East Tenn
    Yes, some Nice Installs over there - don't see any second Story with Outside Protection Covers & Long 90's
    How's Drilling through Hard Brick at 10 Degrees or so ?
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
