Results 1 to 9 of 9
    Mar 2018
    WebCTRL 4.1 runs on my 64 bit win7 machine, but not on the customer's 64 bit win10.
    I've got a customer with a 4.1 database whose server went down. We are replacing it with a new machine; WebCTRL 4.1 installs fine, but none of the applications will run (eikon, sitebuilder, server). Everything runs fine on my machine running windows 7, but they want it on their machine. Would buying a windows 7 license do the trick?
    Is this a windows 10 problem or am I missing something?
    California
    Simply put...your going to have problems. It likes 32 bit. Even IF you get it to work. Why? 7 should work fine....but 10???? It's a lost cause if it's not supported by the manufacture.
    I would ask the customer "why are you upgrading the computer?" If it has internet access you better upgrade WebCTRL.
    SE Wisconsin
    WebCRTL v6.5 is the first to be supported on Windows 10.
    I had another customer try something similar with 5.2 last week with similar results. In both cases i see the customer purchasing a 6.5 license upgrade.
    On a positive note the upgrade is cheaper than a new license. So there's that in your favor.
    Ken
    May 2009
    SC
    Another upgrade WebCTRL vote. The new HTML5 web interface alone is going to make it worth it.
    Otherwise stay on a supported OS.
    Mar 2018
    Quote Originally Posted by control$ View Post
    It is a windows 10 issue. To everyone suggesting that the customer buy an upgrade, it won't happen. They don't have the budget to upgrade the hardware. They're on a new server because the old one crashed. An upgrade definitely would solve the issue, but they won't do business with the local branch because it's a garbage factory.
    May 2009
    SC
    Well win 7 has a couple years left in it.
    Otherwise try win 10 32bit. That has more of a chance of working.
    Mar 2018
    Quote Originally Posted by MaxBurn View Post
    Nah, I know 4.1 will run on a 64 bit win7 machine.
    May 2009
    SC
    Quote Originally Posted by Mikemikemike View Post
    It will, and it will have issues with certain situations. I had one where sitebuilder would crash when opening the file chooser window to go get the patch file. There was a couple other similar crashes all centering around any time it needed to look at files on disk it would crash. None of the compatibility modes helped. I wanted it on a tech laptop but I wound up putting it in a VM.
    Mar 2018
    Not surprised. I would love for their system to work seamlessly but they have what they have and they want to spend as little as possible so there it is. FWIW I suggested they flood the place and take the insurance payout but no one ever listens to me.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
