Results 14 to 17 of 17
    Virginia
    Foot pump might clear the clog from the trap , but where does the shit go after that ? ?
    I use a shop vac .... OR take my trap brush , shove it thru , then cut the pipe , then take my garden hose , butt up against pipe going out , duct tape together , pull the trigger
    Garden hose definitely does it best
    May 2014
    Bay Area California
    What? You don't just put your lips on the vent and blow?
    If you were a real tech, you'd solder a relay on that board and call it good to go.
    I do a triple evac with nitro to remove non condensables.
    I use 56% silver on everything except steel.
    Did you really need the " If you were a real tech " ??
    Dec 2012
    columbus, OH
    Quote Originally Posted by Snapperhead View Post
    It comes out of the pump. You’d be surprised foe much gunk it can move. It does plug it up on occasion an you need to take the check valve off, tap it out and rinse it.
    May 2018
    FLORIDA
    why just not a 2 gallons shop vac, i use them every maintenance, not to expensive and can solve a lot of problems
  5. Likes joemach liked this post
