Results 14 to 26 of 27
    SE Michigan
    The Lennox merit series will fit in the alcove...a 3 ton is 24 1/4 x 24 1/4...which will fit fine. The 4 ton there is oversized for the envelope and for the ductwork.
    Problem is, Im not a lennox dealer. May have to ask HeyBob if he can call in an order for me.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    Mar 2013
    Billington Heights, NY
    Quote Originally Posted by coolwhip View Post
    The Lennox 13ACXN is roughly 29Hx24Wx24D, 3 ton 13J04. If he cant, I probably can. Im on a cash account so you can pay on pickup at your local PartsPlus store.
  3. Likes coolwhip, DavidDeBord liked this post
  4. #16
    SE Michigan
    Thanks Marc..appreciate it!....I got to put together a proposal for a new furnace, ac, and 2 zone panel. Im sure it will be approved, because this lady luvs me.
  5. Likes HVAC_Marc liked this post
  6. #17
    Mar 2013
    No problem. You have my email via my profile or PM should you need it.
  7. Likes coolwhip, DavidDeBord liked this post
  8. #18
    May 2018
    Knoxville, TN
    Quote Originally Posted by HVAC_Marc View Post
    Parts plus will sell any hvac contractor merit line equipment, so he should be good to just go get it at the supply house. Its just the Elite and Signature series that are Lennox dealers only.
  9. #19
    Myrtle Beach, SC
    Armstrong is made by Lennox. Some of their equipment is the same as Lennox.
    Remember, Air Conditioning begins with AIR.
  10. Likes HVAC_Marc liked this post
  11. #20
    Mar 2013
    Quote Originally Posted by Thassel8 View Post
    Not here they wont.
  12. #21
    May 2018
    Knoxville, TN
    Not here they wont.
    That is kinda surprising, Local partsplus here lets anyone with an EPA buy them, just not the high end equipment. Could always use Armstrong or concord, some of them use the same designs.
  13. #22
    Mar 2013
    It's "no account, no sale" here. Except when you BIL goes in and lies to them. That got a damper put on it too...
  14. #23
    Jul 2016
    Ontario, Canada
    Quote Originally Posted by TechmanTerry View Post
    I have had GREAT/SPECTACULAR/AMAZING/GOOD/BETTER THAN GOOD results by installing a "chimney" on top of the CU,depending on situations ,8-10-14-24-36" high. By doing this ,you break the "air trap" recirculation of the discharge air
    right into the suction air.
    Next time your on your knees on a res style cond unit, slowly raise your hand straight up the side of the CU and keep raising your hand higher than the top of the CU. At what height above the CU do you feel discharge air hitting your hand. 2-3-5"??. I have hundreds of "collars" out there. Square,rectangle,oval,octagon,round, most are round. On multi fan condensers I have 2-3-4 chimneys 4' high, some have 45* elbows on top. Hundreds of them. Oh a word of advice, do not leave the sheetmetal edges "raw", have them "hemed" or file them.
    I have make more than a few collars out of wood. I've had customers that have their carpenters make them out of "matching" the house exterior stuff or deck matching material. Cedar,Oak,Redwood,etc
    You can test this out by using crappy/junky cardboard, have your hi side gauge on before/after making and using the chimney and watch that head press drop, watch that low side press drop, watch that "flood" that happens at the condensate drain. And last but not least, watch the amp draw drop also.
    Next time your working on one of those "space restricted" CU put several digital thermometers at diff heights up/down the sides of the CU close to the bldg and see all of the diff air temps going into the CU.
    That’s a very interesting idea, can’t imagine it being very pretty in most applications. Do you ever have any issues with the static created by them?
  15. Likes DavidDeBord liked this post
  16. #24
    Dec 2016
    NE Ohio
    Concord is manufactured by Allied Air (Lenox, Armstrong, Ducane) and is the same size 4AC13*36P W24.25 D24.25 H29 DB74
    You'll be stuck with 13 seer equipment
    Most distributors don't require a franchise on Ducane and Concord
  17. #25
    Nov 2010
    Cincinnati, OH
    I'm not a dealer but have an account at partsplus and they just won't just sell me the merit line they were pushing me on them when I opened the account.
  18. #26
    Mar 2013
    Ive noticed that every store is a little different. They shouldnt be pushing the Signature or Elite lines but I see no problem with Merit or Aire-Flo. They all require an account here for any kind of sale.
