Page 2 of 9 FirstFirst 123456789 LastLast
Results 14 to 26 of 111
    Jan 2005
    Akron
    Quote Originally Posted by acguytx View Post
    and a picture and info..it seems as if this is the unicorn of tools lol
    Here are the initial specifications and accuracy statements, they are subject to small changes, but they are pretty well locked in. We are hoping to have the beta units by the middle of the month for final approval and inventory in August. We found a few bugs with the alpha unit that resulted in delays, but it will be worth the wait. We have a lot of plans on the app side that will make it an exciting product.
    Jim
    JLB,
    Nov 2008
    DFW,TX
    Quote Originally Posted by jim bergmann View Post
    Jim
    thanks
    Jan 2002
    Chicago area, Il.
    Jim, am I reading this right, the iDVM 550 doesn't do DC amps, and doesn't do DC microamps?
    Hi, my name is Glenn, and I'm a Toolaholic!
    Quote Originally Posted by Glenn Harrison View Post
    I don't see them either.
    So a 2 meter set up for complete HVAC techs.
    Aug 2009
    Maine
    Maybe in next year's model
    Jan 2005
    Akron
    Those are features in the iDVM510. We added another meter to cover the next set of measurements. The problem with a single meter for everything is it does not do somethings well, or it gets so clunky that it is hard to use. The only way to get the range and the resolution and measurement quality that we needed, in this case, was to do two meters. To be honest, I do not think I have ever carried a single meter in my career.
    The big feature to the 550 is power measurement, PF, THD, and volts and amps at the same time. We needed multiple ranges of power for a high and low range. While some of you may not be measuring power now, I am sure you will see it coming. We already see it in California where we measure fan watt draw. It is also needed for EER.
    JLB,
    Chicago area
    What is THD?
    Oct 2014
    Columbus, Ohio
    Quote Originally Posted by heatingman View Post
    What is THD?
    Total Harmonic Distortion, a measurement of noise on the line.
    Nov 2008
    DFW,TX
    so maybe im tired and not fully awake but what do those measure on hvac systems? Variable speed Motors and the like? i rarely use dc maybe working on my vehicle testing 12v stuff etc..enlighten me on what id be missing on not having these functions in the HVAC field?
    Jan 2005
    Akron
    Power is used for EER and approximate SEER. You need a true power meter to do this as Volts x amps x Power Factor actually equal Watts in an A/C circuit.
    THD is used to identify noise and intern circuits that are overheating, becoming much more common with digital switching. (electronic loads) This typically results in overheating the neutral
    We measure and correct power factor, low being the cause of excessive current draw and high utility bills. Many times you will see a shift in power factor as a result of a failing capacitor.
    Inrush, current and its duration are used to identify the need for moving a load to another circuit or the addition of a hard start to a compressor.
    Additionally, the meter has a very high-resolution clamp for high accuracy measurements of low current loads.
    Last, we are making a full diagnostic app behind it to assist with identification of these problems.
    JLB,
    Aug 2009
    Maine
    So is the 550 an amp clamp?
    Jan 2005
    Akron
    Quote Originally Posted by lytning View Post
    Yes
    JLB,
    Where the grass is green and the girls are pretty
    Cool
    No wonder it took a little longer.
