Results 1 to 10 of 10
Thread: Motor Age Help
    May 2018
    Motor Age Help
    I need to find the age of several GE motors. I haven't been able to find a breakdown for model / serial numbers on the nameplates of GE motors. Does anyone have information about the date codes used on the nameplates of GE motors? (Example: Model: 5K43KG2802H / Serial: ERL//)
    Baldor Motors? (The date code info on their website seems to not be used as part of their serial numbers anymore)
    Aug 2013
    Visalia California 93291
    do you have model and serial of the equipment
    May 2018
    Aug 2013
    Quote Originally Posted by ChicagoEng View Post
    The equipment the motor is installed on, not the motor numbers
    May 2018
    No nameplate on the unit this is on or any of the 10 others with the same motor..
    Aug 2013
    Well the motor # is going to be specific to the MFG of the equipment it is installed on
    May 2018
    Another unit (air handler) has a newer GE motor: Model: 5KS254ATE205AE2 / Serial: 115352014
    This I am assuming is from 2011, but I was hoping to be correct and not guess.
    May 2018
    The units with the Model: 5K43KG2802H / Serial: ERL// motors can all be assumed as original motors which would put them at 40 years old (original to the building). Anyone know if or when GE motors switched to a date code naming in the serial number (does ERL stand for 1978)?
    Jun 2010
    Miami
    Does October 1971 sound about right for the original motors?
    Current date codes are in model numbers and repeat on 42 year intervals.
    May 2018
    1971 sounds a little early. One of the units does have a nameplate: Champion Blower Model: 122-BBE VENT PAK / Serial: L-79214-12 E-9. This leads me to believe most of the original equipment is from 1979.
