Results 1 to 13 of 29
    Feb 2017
    New York
    Stripped thread repair on condenser pump
    Hey guys, looking for some ideas.
    I've got a 40HP Taco condenser pump that has stripped threads for the rear cover. The motor sits vertical so the owner wants it repaired. It looks like the 2 bolts (1/4-20) were loose and just wore out the aluminum.
    Here's the killer, they are not blind holes and go into the bearing cavity. I'd like to go to a 8mm 1.25 pitch so I shouldn't have to drill. I'm worried about getting material into the bearing cavity. I'll use grease on the tap and clear it often.
    I was also thinking about filling the cavity full of grease and pump some more in pushing whatever is in it back through the holes.
    The cover itself will be easy to open up for the larger bolt.
    Any other ideas? I really don't want to diassemble the motor to do this...
    Sent from my SM-G920V using Tapatalk
    -----Stop, step back, relax and have another go at it.-----
    up in the hizzy
    How bout helicoils in the existing holes? I never seen an aluminum made Taco, whats the series? FE FM FI ??
    There is not better place for the working men than the union! 100% UA the only HVAC union!
    Feb 2017
    New York
    The rear bearing cover of the motor is aluminum. It's a Baldor motor if memory serves me right.
    I'm leaning on ruling out Helicoils due to the fact that there may be 3/16 of material at most.
    Not sure on the series. I'll be back tomorrow for pump, strainer and chiller PMs. Got the tower cleaned today.
    Edit: Sorry, meant to quote your post. Also, don't you have to break off the tab after installing it? How would I keep it out of the bearing cavity?
    Chicago area
    Its AL, so lubrication should not be much of an issue, high carbon tool steel is way stronger then cast AL.
    Id prolly just have someone hold a vacuum next to the tap, and do it dry.
    Feb 2017
    New York
    Quote Originally Posted by heatingman View Post
    I've had billet aluminum gall without proper lubrication. I don't think there should be a problem with cast. I picked 8mm bolts because the ID is just over the OD of a 1/4-20 bolt. That way I just need to tap.
    The Hot South
    Is the rear bearing cover on the Baldor motor? Not the pump? Pics?
    The 2nd most important amendment is to protect the 1st....
    Free Air Conditioner Sizing Chart
    Feb 2017
    New York
    Quote Originally Posted by R123 View Post
    Sorry, didn't think of getting pics at the time. Yes, it's the motor that needs repair. Just Googled it. It's a Taco TS series pump. It's the splash guard on top. It bolt to the motor right near the bearing.
    Edit: Sorry, it's a KS
    Feb 2017
    New York
    I'll mull it over tonight. Almost time to hit the hay. I'll check back in the morning. I'll take some pics of the repair.
    Chicago area
    Maybe a touch of antiseize on the tap, and call it a day.
    Nov 2011
    East Side
    It’s just two bolts that hold the splash guard on the motor, nothing else “structural”?
    Mar 2010
    Sunny SoCal
    Quote Originally Posted by BennyD View Post
    If thread repair doesn't work out how about making two, three or four thin flat bars with a 90° tab on one end & strap them to the side of the motor via a couple of large worm drive (hose) clamps.
    Then mount the water gard to these bars.
    It won't look as clean but perhaps it will be robust enough to do the job???
    (Tape each bar to the motor one at a time to temporarily attach with proper alignment before clamping all permanently).
    Eric
    Feb 2017
    New York
    Quote Originally Posted by 71CHOPS View Post
    Correct
    Feb 2017
    New York
    Well, the owner is a bit leery of tapping the holes. Looking at it more (I promise to send pics), I may make a couple small brackets that will bolt to the studs that hold the motor together. They will have 2 opposing bends like a "Z" channel. There is enough stud to put that over and put a nut on it. I'll drill the cover to bolt the bracket to it.
    The center has 4 bosses in the bottom, 2 with bolt holes for the cover. I'll rotate the cover 90° so the other 2 will cover the holes to the bearing.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
