Page 3 of 3 FirstFirst 123
Results 27 to 29 of 29
  1. #27
    Madison, WI/Cape Coral, FL
    Glad to here from you again.
    Do you consider fresh air change and maintaining humidity levels to be part of good indoor air quality?
    If so how much air change and what humidity level.
    Keep us posted.
    Regard Teddy Bear
  2. #28
    Dec 2015
    Austin
    Quote Originally Posted by shane1900 View Post
    Randy can you share a link to the 15 lb carbon filter you are using?
    Here's the carbon filter- https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Here's the matching inline fan - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    It's loud, not pretty and aimed at the marajuana growers market -But it's very impressive in reducing VOC levels measured with an industrial PID meter.
    My go to device used to be the Austin Air HP+, but this device offers significantly better results at about 1/3 the cost.
  3. #29
    Dec 2015
    Austin
    Here's the link to the Austin Air device I was using previously.
    Probably a safer bet than the other device as regards warranty and an established company:
    https://austinair.com/shop/healthmate-plus/
    A Canadian company, Airpura, also makes reputable devices.
    The TeraBloom units I referenced though had significantly better VOC reduction numbers than the Austin, but it's ugly, loud and I don't know how long the carbon will take to saturate.
