Results 1 to 9 of 9
    Jun 2006
    Victoria, Texas
    Mini Split problem
    I have a customer with Heat Controller Mini Split Heat Pump model A-VMH24SB that the outside fan won't cut off. The only way to stop the fan is to turn the breaker off. Has anyone seen this problem before or a tech support number I can call for help.
    Sep 2016
    If it doesn't shut off even when the remote is turned off, you most likely need to replace the board outside. The tech support number for Heat Controller (now Mars) is 517.780.3208
  3. Likes Codecheck8888 liked this post.
  4. #3
    Jul 2013
    Richmond, VA
    Is the compressor running? Ordinarily, inverter systems will run non-stop.
    Sent from my iPad using Tapatalk
  5. #4
    Mar 2018
    Could be thermisters out of range. Ohm and compare to what they should be from mfg.
  6. #5
    Jun 2006
    Victoria, Texas
  7. #6
    Nov 2014
    Chicago Illinois
    Circuit board
  8. #7
    Sep 2018
    San Francisco, CA
    I agree as for the board. Also, you have a nice avatar (sorry, it couldn`t be helped).
  9. #8
    Nov 2014
    Chicago Illinois
    Nov 2014
    Chicago Illinois
    By the way did you ever get down to the bottom of this issue? Curious to see what ended up being a solution like I said Im pretty sure I have something to do with the board
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
