Results 1 to 15 of 15
Thread: Need Assistance Trane Reliatel New Unit Install
    Mar 2009
    MIAMI FL,
    Company just installed a new TZC036E unit with RTEM, RTOM AND RTEM boards in it. Unit supplied by customer with Trane THC2775 thermostat. Unit not responding to thermostat, called Trane tech support, says that unit requires zone sensor to operate. Called tech support again today for correct zone sensor and now they say unit cannot run off of thermostat at all, VAV unit which requires BAS control. Doesn't make any sense to me as I read the IOM it states that unit can run off of BAS, zone sensor or electromechanical stat. This is a brand new 2018 unit, does it require an additional conventional interface board to use a local thermostat? Do I need to use a baysens zsm? Trane tech support isnt helping at this point.
    Oct 2014
    Columbus, Ohio
    I can't find any info on your stat's part number. I've installed Precedent split systems before, and they would work with either a zone sensor or a regular old thermostat. I assume most of the reliatel controls are essentially the same whether they are in a package unit or a split system.
    Mar 2018
    Montreal, Canada
    If they are like the older Voyager units, then yes, you need an interface board if you want to use a standard thermostat.
    Jan 2010
    How about a complete model #
  5. Likes rjk_cmh liked this post.
  6. #5
    Apr 2008
    Tucson, AZ
    Quote Originally Posted by haig1 View Post
    Reliatel boards do not need an interface board. They have Y1, y2, etc, terminals so can work with regular t-stats.
  7. #6
    Apr 2008
    Tucson, AZ
    Quote Originally Posted by JAYYJR View Post
    Trane only helps Trane employees I have found. It seems to be their business model idea to force people to hire Trane perhaps.
  8. #7
    Southeastern Pa
    If you use a Trane thermostat you have to connect to the terminals for that type of thermostat, and if you use a conventional thermostat you can connect to the conventional terminals, which are obviously labeled.
    As a test, why don't you connect a spare thermostat and a short length of wire to that board and see if the unit responds as expected?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  9. #8
    Virginia
    Quote Originally Posted by rjk_cmh View Post
    I'm pretty sure that should be a Trane THT02775 thermostat.
  10. #9
    Feb 2012
    How is that thermostat currently wired up in the unit?
  11. #10
    Apr 2018
    torrington CT
    if the reliatel board has conventional terminals then ou can use a conventional thermostat. double check your thermostat wiring
  12. #11
    Oct 2005
    So the unit will be used as a VAV unit?
    Not saying it cant be done but ive never seen a newer Trane VAV unit with a conventional thermostat. You will need a simple Trane zone sensor installed on terminals 1 and 2. The unit will need to be set up correctly if it will be used as VAV. Highly recommend googling for the Reliatel manual, with all them extra control boards im sure the unit is gonna require alot of bucket time. Good luck.
    RTFM!!!
  13. #12
    Southeastern Pa
    I would check that IOM for VAV-specific instructions. I missed this part of your first post. You typically do not use a thermostat in those systems.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  14. #13
    NYC
    If it's a VAV unit (has a RTAM installed), you don't typically use a conventional thermostat.
    Normally, they're set up to run off a BAS system, as a standalone through the potentiometers on the RTAM in conjunction with a zone sensor, or with a programmable zone sensor.
    Don't forget to wire the VAVs into the VHR relay (if not using BAS control) if you're using morning or daytime warmup.
    The IOM should tell you everything you need.
    UA LOCAL 638- The Enterprise Association of Steamfitters
  15. #14
    Feb 2012
    Quote Originally Posted by timebuilder View Post
    Not gonna lie.. I didn't notice the vav part either lol
    In that case, most of the ones I've seen have a CCP set up.
  16. #15
    Where the Women are fast and the horses are pretty...Tennessee
    You need to know what you have. Is it VAV, single zone VAV, or CV? Was there an engineer involved that can help? Model and serial numbers are usually needed to get help.
