Thread: Need a 6-way or dual 3-way valve for refrigeration (not water)
    Oct 2014
    Columbus, Ohio
    Question Need a 6-way or dual 3-way valve for refrigeration (not water)
    I'm trying to find either a single-module 6-way valve or a set of 3-way valves that I can combine with a common linkage. I want to use some kind of electronic actuator, and I would prefer that they NOT be pilot-operated valves. Most likely refrigerant will be R410a or R134a. Any suggestions?
    Quick reply to this message Reply
    Jan 2010
    Sea to Sky
    Size matters, especially if trying to avoid pilot operation...you might want to give us a hint.
    Sent from my SM-N910W8 using Tapatalk
    Oct 2014
    Columbus, Ohio
    Quote Originally Posted by BALloyd View Post
    This is the application: http://hvac-talk.com/vbb/showthread....covery-chiller
    I don't know the size yet, I'm just trying to identify a product line to start with that is best suited to my use-case, and then I can figure out sizing from there.
Quick Reply Quick Reply
Register Now
Log-in
