Page 6 of 6 FirstFirst 123456
Results 66 to 70 of 70
  1. #66
    Southold, NY
    Quote Originally Posted by tvpbnl View Post
    Yes, POE is very hydroscopic. On this job the unit was open to the atmosphere. New dryers are installed. To minimize the POE coming in contact with moisture, evacuate your system after leak checking. Since we have a measured amount of oil you can break the vacuum by drawing out the oil before adding the new refrigerant.
    If you suspect contaminated oil (Haven't run across that a whole hell of a lot) change it before pulling a vacuum. Why open the system after!
  2. #67
    Jul 2012
    I do oil changes before the evac. Oils do mix. Dont believe the hype.
  3. #68
    Feb 2017
    New York
    Quote Originally Posted by captaincompressor View Post
    Same here, I always pull on fresh oil! I do a bit of chiller work. Even with mineral oil, you should see how much comes out of it when the vacuum gets deep through the sight glass.
    Sent from my SM-G935U using Tapatalk
    -----Stop, step back, relax and have another go at it.-----
  4. #69
    Southold, NY
    Quote Originally Posted by BennyD View Post
    Chillers are a completely different story!
  5. #70
    Feb 2017
    New York
    I know, just making a reference that even if the oil is fresh out of a container, there still may be some crap in it.
