Results 1 to 8 of 8
    Apr 2003
    St. Louis
    ceiling fan remote control after market for led bulbs
    Have two fans with older remote controls that will not work with cfl or led bulbs, they flicker. Thinking about adding a small relay to the lighting output of the controller so then it would switch 115v on and off to the bulbs but don't know if the controller would have the same problem with the relay coil as a bulb- flickering.
    Try the Sylvania LED14A19/DIM/0/827/RP lamp. This lamp looks like it has Fins on it. It sometimes flickers while dimming in my hunter remote control fan, but once the dimness is set it stops flickering and settles out.
    Bar Code #46135 72565. 14W 75W Equivalent 1,100 lumens 2,700K
    Retired, after 43 Years
    Mar 2015
    Hamersville, Ohio
    What is causing the voltage drop? Or "Pulsing Voltage"?
    A standard incandescent dimmer actually turns the lamp on and off repeatedly. You don't see the flicker due to the speed of the switching. This messes with the electronics in a LED lamp.
    Apr 2003
    St. Louis
    Madhat didn't know that, thanks
    Mar 2015
    Hamersville, Ohio
    If, I remember correctly,... The LEDs have internal circuitry?
    That makes since that any external pot switch, rheostat, would interfere with these bulbs.
    Kinda like having a wife & a girl-friend, .... The two can't work together.
    LED Dimmers, for dimmable lamps, also do an on and off, but they do it with Pulse Width Modulation, the voltage goes up and down, but is never completely switched off. I think this wave is much faster than the incandescent dimmers on and off cycle. I haven't been able to check these dimmers with an O Scope.
  8. Likes DavidDeBord liked this post
  9. #8
    Mar 2013
    Billington Heights, NY
    Quote Originally Posted by DavidDeBord View Post
    Been there, done that. They can if they like each other
    Lights in fans are controlled directly off the switch. So, to prevent flickering issues you need a fan compatible/LED/CFL dimming capable switch AND CFL/LED lights capable of dimming. Correct wiring to the switch and light is also a necessity.
  10. Likes DavidDeBord liked this post
