+ Reply to Thread
Results 1 to 10 of 10
Thread: Geothermal AC not working
    May 2017
    Good afternoon folks... I am at wits end. (i have a pro coming in a couple days). ive been a homeowner with geo for 4 years. we built this house and its everything we want. except about 3 times until recently per year the geo ac would stop working.
    Its a Honeywell board.
    Anyway, what happens or is happening now is Cool 1 is green (meaning its on) and fan is green (meaning on). Cool1 is on for zone 1 which is upstairs.
    problem is zone 1 is 75 degrees when the thermostat is set to 71.
    If i trip the breaker or run a purge by stepping through the settings (it does it automatically) it switches on, cools for a bit, then goes right back to this.
    I have NO idea what the tech has done 10 times prior to fix it, but it works for months or til the next summer. But I fired those guys and am working with a new company that supposedly knows more.
    Problem is, they cant get here til tuesday and its warm.
    Any help would be appreciated.
    thanks
    Jan 2012
    Missouri, USA
    Any refrigerant added in the past?
    May 2017
    Quote Originally Posted by ksefan View Post
    its only a fur year old system and its been doing it since year 1 , 3 months after we moved in... i cant imagine it needed refridgerant that quickly..
    in case the people that did it are that dumb, how would i go about checking it? its a full geo system, so no outdoor unit at all.. im not an hvac guy at all.
    thanks
    May 2017
    ok, im 99% sure i figured it out.
    The pvc drainage pipe running from the unit to the drain was not acting right... I had to get a little rough with it but I managed to loosen a midway spot and opened it up there... water came pouring out , probably near a gallon in total.
    That alone threw up warning alarms for me. Im not an hvac guy as I said, but I know that the drain is a trickle, not a deluge.
    I looked in the pipe that i took off and it was clogged tight.. completely sealed off. I rapped it on the concrete and all this junk came out. Replaced it and the flow is great again.
    The unit kicked on and the cold air is flowing. Now I could get it to pump some air temporarily, but never more than 15-20 minutes. we will see how this goes, but im fairly confident in the fix.
  5. Likes ksefan liked this post.
  6. #5
    Jan 2014
    Sounds like sludge buildup in the condensate then the system goes into a condensate overflow fault.
  7. #6
    Dec 2022
    Winnipesaukee, New Hampshire
    Put a cup of bleach in your evap coil pan in the spring
  8. Dislikes kdean1 disliked this post.
  9. #7
    Dec 2022
    Quote Originally Posted by CraftyDus View Post
    And if you don’t like that try in your evap coil pan in the spring
  10. Dislikes kdean1 disliked this post.
  11. #8
    SE Ohio
    Thank you sooo much for reviving a 5 year old thread.
  12. #9
    Dec 2022
    I thought you were serving up the dislikes for some weird pro-fungus-in-the-drains stance.
    Now I understand its the thread necro police.
  13. #10
    Jun 2014
    Dover, DE
    The poster that started this thread hasn’t even logged onto the site in almost 6 years. Let alone been active.
    “I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
    “It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
