Page 3 of 3 FirstFirst 123
Results 27 to 30 of 30
  1. #27
    Oct 2019
    DR65 is right option but why the contractors are saying that higher capacity will be ideal? If you do not mind higher energy cost then go for it. But higher capacity dehumidifier does not make sense. Please do not only rely on dehumidifier and keep your HVAC filters clean to keep the air quality fresh.
  2. #28
    Jan 2005
    teddy what is the preferred method to bring in fresh air with the 65 Honeywell?
  3. #29
    Madison, WI/Cape Coral, FL
    Quote Originally Posted by opey456 View Post
    Install is important. If you want 60-70cfm of fresh air, a 6" insulated duct from the fresh air inlet grill with a screen to the dehumidifier. The small whole house units have an 8" duct inlet. A tee is needed to combine the 6" to the 8" return from the open part of the home. Avoid connecting the dehumidifier return to the a/c return. If the fresh air duct is more than 20 ft long, upsize the 6" to an 8" to avoid excessive air flow restriction. Some add an adjusting damper for fine tuning and also a electric damper for switching on/off.
    Fresh air should be on during occupancy especially during mild weather/windows closed. During the coldest winter weather when the home is too dry stop or slow fresh air.
    Welcome aboard fresh air and humidity control.. Keep us posted on how it works out.
    Regards Teddy Bear
    One more important point is that your a/c is setup with correct amount of air flow through the cooling coil. A good a/c setup with maintain <50%RH when the a/c is operating +50% of the time without an assistance from the dehumidifier. If not, adjust the air flow through the cooling coil to remove enough moisture. A good tech will do this for you.
  4. #30
    Jan 2005
    Yes we usually setup our units for proper airflow to maintain good humidity setting. But with everyone foaming houses now we are starting to see more of a need for dehumidifiers, and wanting to bring in fresh air also. Just was curious your preferred method. Some install manuals can be pretty vague as to what works best.
