    State College, PA
    Interesting electrical issue
    I went to a hot water heater today that was not working. The breaker was not tripped, but I turned the breaker off and back on and the water heater was working again. I waited until the top element was satisfied and the lower element was energized and did not kick the breaker.
    We had a storm a few days ago and that is when it was reported that the hot water heater went out. This was Square D QO breakers. Any ideas on what is going on here. Bad breaker?
    I called it good for now to get them some hot water and will see if it goes out again.
    Never say this happen before.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
    Oct 2007
    Austin Texas
    Two pole breaker? Maybe half of the breaker was tripped? I've seen that a couple of times on 2 pole breakers for clothes dryers. The drum would turn, but no heat.
    Nemo me impune lacessit.
    How much blood do I have to bathe in to get clean?
    Don't look down on anyone unless you're helping them up.
  3. Likes skwoodwiva2 liked this post.
  4. #3
    Jul 2002
    Yuma, AZ
    Amp draw/breaker size?
    Loose connection at breaker or bus bar?
    Teach the owner how to reset a breaker.
    One trip does not warrant a breaker replacement.
    "I have never let my schooling interfere with my education."
    Mark Twain
    NEVER STOP LEARNING.
  5. #4
    Apr 2017
    Athens, Wi
    I can't even count the number of times I've reset a breaker that didn't flip the handle over... One of the first things I do on a no power call is run my fingers down the breakers to see if a handle is loose and will flip to off or tripped with just a bit of pressure.
  6. Likes lynn comstock liked this post.
  7. #5
    State College, PA
    Turns out the tenant pushed the breaker to the on position after it tripped without cycling it fully off first. All has been working OK since I reset it.
    Thanks for all the input.
