Results 1 to 13 of 34
    Oct 2016
    Ventilation Using Ceiling Fans
    Greeting,
    I am working on a project that I was asked to design the ventilation just using ceiling fans. The application is storage building. I can design the number of the fans based on the required cfm but I am wondering how we need to provide vents for exhaust air and window for fresh air. Do you guys have any experience with similar project?
    Madison, WI/Cape Coral, FL
    Quote Originally Posted by HVACMAN20 View Post
    Greeting,
    Location, heating, and cooling? How much ventilation or circulation?
    Looking forward.
    Regards Teddy Bear
    Oct 2016
    It is located in southeast TX. I am providing 32000 cfm ventilation using three ceiling fans. No cooling or heating requirement just ventilation.
    New Mexico
    Does the design just want to move existing air around?
    Or has the owner/designer not considered this?
    Give me a relay with big enough contacts, and I'll run the world!
    You can be anything you want......As long as you don't suck at it.
    If a person wants to create a machine that will be more likely to fail...Make it complicated.
    USAF 98 Bomb Wing 1960-66 SMW Lu49
    Desert Southwest
    You could put a window fan or fans at one end of the building and exhaust fans at the other which will give you ventilation.
    With vents nothing will bring in fresh air unless it gets windy outside. Ceiling fans will indeed move the air around as said but that is not ventilation.
    If you can't fix it with JB Weld, Duct Tape, and Ty Wire it has to be replaced.
    No good deed goes unpunished.
    If you want to take off friday to go fishing then make sure you train your helper right.
    Oct 2016
    Quote Originally Posted by hvacker View Post
    The intention of these fans is to more than moving air around. The expectation is to do also air change. That is why I am asking to see if any one has done similar job.
    Oct 2016
    So you recommend to have additional fan(s) to push the air out. You are saying me to install fan(s) with 32000 cfm for ventilation? Therefore, what these big ass fans do would be moving air around, am I right?
    Oct 2016
    Quote Originally Posted by desert guy View Post
  9. Likes lkapigian liked this post
  10. #9
    Aug 2013
    Visalia California 93291
    Unless the ceiling fan is "ducted " the only air change you will get will be natural ventilation which will vary with indoor and out door conditions, wind speed outside ETC...A ceiling fan in itself will not create an air change
  11. Likes armandomartinez liked this post
  12. #10
    Oct 2016
    Quote Originally Posted by lkapigian View Post
    Thanks. Do you have sample of ducted ceiling fans?
  13. #11
    Aug 2013
    There are none, it was an analogy...there are however plenty of fans, prop, forward curve , backward incline etc that will fit your bill. Start with your target ventilation needs/requirements
  14. #12
    Oct 2016
    Lol. Sure, Thanks.
  15. #13
    Jun 2014
    Dover, DE
    There is no such thing as ventilation using only ceiling fans. Ventilation by nature is exchanging the air within the space.
    What's the engineer call for building air exchange?
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
