Results 1 to 12 of 12
    Sep 2016
    conneticut
    Is anyone still getting dry r-22 condensers
    In my area there haven't been any available for a few months. Just curious is all.
    Southeastern Pa
    You can't get them anymore.
    You CAN get 407C condensers, though.
    Practically identical....
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Sep 2016
    conneticut
    Wasnt aware of that thanks
    Tucson, Arizona
    The dry units here were all 13SEER, once the supply was gone, we can't get any more. I've seen advertisements for the 407c units, but they are not in stock locally yet.
    There are two ways to do things, Right and Again.
    kansas
    Check uri
    Honeywell you can buy better but you cant pay more
    I told my wife when i die to sell my fishing stuff for what its worth not what i told her i paid for it
    Apr 2018
    San Francisco
    Not available anymore....In 1987, there is a mandatory phase out of certain products whose emissions were deemed harmful to the environment. In the US, the protocol was put into law through the Clean Air Act, and is implemented by the EPA. The law requires a phase out of R22 as a refrigerant. So after few years the supply was decreasing...
    Mar 2013
    Billington Heights, NY
    Quote Originally Posted by runnerman1 View Post
    R407C units are basically R22 units. Amazing how a simple change of lettering skirts the rules.
  8. Likes buttwheat liked this post
  9. #8
    Tucson, Arizona
    The R407c units are in stock locally in 14 SEER now. I installed one this week. They are almost dry ship, because they only have 1 pound of R407c in it. The one I installed took 6 pounds, they are a nice option to add for budget projects.
  10. #9
    Oct 2014
    Columbus, Ohio
    Quote Originally Posted by shavedneon View Post
    Why only 1 pound instead of either a full charge or a nitrogen charge?
  11. #10
    Quote Originally Posted by rjk_cmh View Post
    I would assume cost is the number one reason and 2 is so you can pull it easily and charge with R22 if you want to.
    Commercial condensers usually come with a holding charge of about 1 pound of refrigerant and the rest is field charged. So I guess that’s where they got the idea.
  12. #11
    Tucson, Arizona
    I actually asked that exact question, the answer given, it’s part of the loophole that allows them to sell those units. I gave the R407c option only because it was quicker for me to get them cooling again when I found their compressor shorted to ground.
  13. Likes rjk_cmh liked this post
  14. #12
    Atlanta GA area
    In my area (lots of hacks)... dry units got charged without pulling a vacuum on the unit...
    Thus mixing the N2 holding charge with the refrigerant (not kidding, I found this repeatedly).
    So if the factory puts just a small holding charge of 407C in the unit... then the hack installer can pull a vacuum on only the lineset and coil (like they normally do with a coil change)... and charge with 407C.
    I am gonna have to talk to the guy at URI... if they are gonna get '14 SEER 407C units'... I may well use them as an option! Reason is: lower pressures should mean longer evap coil life!
    GA-HVAC-Tech
