Results 1 to 13 of 13
    Sep 2016
    water and refrigerant mix
    hi guys
    any ideas on recovering water and refrigerant mix, The HX failed and filled the system with water.
    I ve already broke one recovery machine, its a 20 ton Carrier with 40 lbs of R22.
    Jul 2009
    In a mechanical room....
    Your gonna need a cold trap.
    “It takes courage to grow up and turn out to be who you really are.”
    - E.E. Cummings
  3. Likes CHILLERSVCMAN liked this post
  4. #3
    Jul 2000
    Dallas,Texas
    If it is full of water the refrigerant is gone already. Refrigerant goes out the same place the water comes in.
    Drain the water out and pressurize with nitrogen to blow all you can out. Then the fun begins.
    You really have to decide if the effort is worth it or a new chiller is the better idea.
  5. Likes stanbyyourword, JCN, CHILLERSVCMAN liked this post
  6. #4
    Refrigerant molecules are bigger than water molecules. Get a done mesh strainer and pour the mix through the strainer and BOOM. Separated chemicals.
    "Right" is not the same as "Wise".
  7. #5
    Apr 2017
    The Deep South
    Quote Originally Posted by wolfdog View Post
    What he said.
  8. #6
    Apr 2016
    Maryland
    Watch vacuum pump oil ; it will get diluted quick . Pump may fail / lock-up. You may want to consider a cradle of nitrogen if access allows. Heat lamps or other heat sources applied to non-insulated sections. If possible valve off sections and place vacuum pumps on each isolated section. Welch 3cfm belt driven vacuum pumps come in handy . Be cautious when pulling vacuum ; too fast is not beneficial for complete moisture removal . Prior to placing in operation suggest Sporlan high moisture capacity cores . Refrigerant and oil samples be taken and sent to a lab to monitor clean-up. It has the possibility to be a long process. Machine will probably start to rust from the inside. Have customer start budgeting for replacement .
  9. Likes fornot liked this post
  10. #7
    Feb 2017
    New York
    Quote Originally Posted by CHILLERSVCMAN View Post
    X2
    Sublimation is not a myth if you have standing water. I've drilled low spots in everything from castings to shells. Tap for 1/8" pipe plug and use brass. I drill low spots in lines with a small bit. Braze up hole when done. You WILL need to babysit your vacuum pump. Plan on 10 gallons of oil plus. You won't be able to let your pump run overnight for at least a few days. Welch pumps deal with water better than most. At least use a pump that holds the most oil. Look into a cold trap to minimize moisture getting to pump. Wash, wash, wash with nitrogen. Like stated, once it's dry, there's already rust.
    -----Stop, step back, relax and have another go at it.-----
  11. Likes CHILLERSVCMAN liked this post
  12. #8
    Jul 2000
    Dallas,Texas
    Quote Originally Posted by jayguy View Post
    Can you recommend a source for a couple of them there strainers?
  13. Likes jayguy liked this post
  14. #9
    Probably find some at Ace Hardware. Got to be REALLY small
    holes though!
  15. #10
    Feb 2017
    New York
    I find coffee filters work well.
  16. Likes jayguy liked this post
  17. #11
    Dec 2001
    Yeah, i used my wifes spaghetti strainer once. She's still pissed
  18. Likes jayguy liked this post
  19. #12
    New Mexico
    I remember a chiller failure like yours where a tech ran a vacuum pump for days w/o good results.
    To get rid of water in a flooded system I once bought a couple gallons of denatured alcohol. Reasoning that alcohol displaces water. Like putting the product Heat in a gas tank. I was a bit lucky as the compressor valves were closed. (don't know why)
    I blew out what I could with nitro then introduced the alcohol and blew it through the system with nitro. (lots of nitro)Alcohol is a fire hazard so I used hoses to blow outside. I used the nitro until my trusty noes test said the alcohol was gone. Then all the other required vacuum, oil change, driers etc. The system worked and was still on line some years later.
    The products available today used with a burnout might do the same thing but would cost a bunch more. R11 used to be used as it has an affinity for moisture but not as great as alcohol.
    Give me a relay with big enough contacts, and I'll run the world!
    You can be anything you want......As long as you don't suck at it.
    If a person wants to create a machine that will be more likely to fail...Make it complicated.
    USAF 98 Bomb Wing 1960-66 SMW Lu49
  20. #13
    Feb 2017
    Australia
    Quote Originally Posted by DLR_LWT View Post
    hi guys
    Sounds like you are in for an enjoyable time
    I have Just finished a York centrifugal which had a condenser tube fail lost 900kg of refrigerant and condenser/ Evap vessel had water in it.
    6 weeks later and a lot of nitrogen,vac pumps,oil and patience the chiller is now back up and operating.
