Results 1 to 11 of 11
Thread: Reversing valve
    Apr 2017
    Reversing valve
    Pressures are equalized in cooling mode, seems to be stuck, liquid line sweating, greenhorn tech, goodman, it's clicking and calling for ac, rv coil didn't have much magnetic pull, changing it today, could it be the compressor, all help greatly appreciated
    Mar 2013
    Billington Heights, NY
    if the valve isnt switching why would you diagnose a compressor? do you get a bigger commission?
    Apr 2017
    I can hear the valve switching, sounds weird not like a full switch, almost like it's bleeding, but the liquid line still sweating, compressor ohms good, clear to ground also, changing valve today, heelllpppp
    Apr 2017
    Didn't recommend compressor,just hate to do this and then have to put a compressor on
    Western Wa.
    Get your post count up and apply for a pro membership to get better answers
    UA Proud
    "Phfft! Facts. You can use them to prove anything." Homer Simpson
  6. Likes weezer81 liked this post.
  7. #6
    Apr 2017
    How do I do that?
  8. #7
    Jan 2014
    New England
    How was the pressures in heat mode, equalized also, ( having your low side gauge hooked to the common suction? )
  9. Likes weezer81 liked this post.
  10. #8
    Jan 2014
    New England
    Quote Originally Posted by weezer81 View Post
    Is this for a customer? If so sounds like a expensive repair for whomever by not dialing in the root cause. Doesn't your company you work for have a senior Tech. versed in Heat Pumps?
  11. Likes weezer81 liked this post.
  12. #9
    Cincinnati, Oh
    Quote Originally Posted by Bazooka Joey View Post
    I was thinking that also.
    I have a policy in place where none of our average techs can diagnose an improperly shifting reversing valve without calling a senior techs.
    It's just to much money to lose.
    A halfway shifted valve is pretty easy to test for using a temp probe.
    Goodman's service manual for your unit does a good job explaining this.
    "Just get it done son."
    Dad adjusted
  13. Likes weezer81 liked this post.
  14. #10
    Apr 2017
    Thanx guys, it was the rv!
  15. #11
    Apr 2005
    Australia : Queensland
    Light tap with a solid object should shift it completely & also your indoor fan will stay off if coil temp doesn’t get to the preset to switch it.
    The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
