True roll in cooler, new condensing unit. Compressor not starting everytime
This single door true Roll in cooler has had numerous compressor changes from another company and cap tube replacements.
Owner wanted problem fixed permanently and gone.
I quoted to replace condensing unit, flush evap and go with a TXV instead.
Replaced the 134a and crap tube with new condensing unit with receiver... an AE4440Z-AA1AGB, and 1/4 ton danfoss TUA TXV valve.
Works and cools great, superheat at compressor is 23F. Problem...
The AE4440Z has trouble restarting sometimes after the off cycle. (Off cycle is usually 8 to 10 mins) compressor pops overload.
Usually after the 3rd attempt it fires right up with no issue.
Start cap is good at 300uf and well within range.
Pulls current, 10a thru start cap when trying to start.
Checked for voltage drop, there is 5 volt drop from 120 to 115V when attempting to start...
Very weird.. I'm ordering new starting components under warranty anyhow but.
What do you guys think?
It should start everytime, its a high start torque model with the 1st 4 in the model #.
Any ideas?
Sent from my SM-N920V using Tapatalk
How are the points on the tstat
Honeywell you can buy better but you cant pay
more
You could install a LL solenoid and make it a pump down system - that will make starting easier on the compressor.
Sent from my SCH-I545 using Tapatalk
Post Likes - 3 Likes, 0 Dislikes
Is the TUA valve a hard shut off?
Originally Posted by
crazzycajun
A12 700 was installed with the condensing unit
shellkamp
No sir, I have used this valve on many other applications.
Ive used it on an old r12 reach in that was controlled thru low pressure and it worked fine.
UmmScott
Yeah, I know, it SHOULD work fine; but it doesn't, does it? :grin:
My gut tells me a pump down solenoid or hard shut off valve would solve this problem for sure. There may be some migration going on
Post Likes - 1 Likes, 0 Dislikes
Are you controlling on a constant cut-in stat? That YOU KNOW for a true-fact is a constant cut-in thermostat?
PHM
UmmScott
Any ideas?
PHM
When faced with the choice between changing one's mind, and proving that there is no need to do so, most tend to get busy on the proof.
shellkamp
Wait...sorry i think i misunderstood.
Yes, it is a hard shut off. It does Not have a bleed port or anything inside it.
Thats what i meant to say.
And PHM yes its an a12 700.
Poodle Head Mikey
PHM
Alright; where are you going with this?
The only way I could relate this issue to thermostat type would be a too-short of an off-cycle.
shellkamp
The off cycle is around 10 mins usually with an empty box.
Thats plenty of off time in my opinion.
Plus...if i unplug/plug in...unplug/plug in a few times every 5 seconds...
Theres times when it will start and theres times when it won't
UmmScott
Then I'd be looking solely at the starting components
No concerns with that head?
Compressor must be starting back up after it cools off a little more.
I'll never understand the fascination with 404 as a Med Temp refrigerant as a conversion anymore. But anyway.
What's the pressures when trying to start? Equalized? Does it always do it on short cycle or will it do it after sitting a while too? As said before, contacts on temp control ok?
Sounds more like either a voltage or starting against pressure.
295? That's what. 115 SCT?
May be a big part of your issue. Things get hot, they get a little tight, a little harder to start? Cool off starts right up?
Hrm. Ok. You converted. I don't see a receiver. Is that a receiver/drier?
I'm wondering if you removed a little refrigerant, which will raise superheat, cause you to open valve to lower superheat and all that will lower discharge.
What's subcooling?
I can't fix it if it won't stay broke..
CRussell1975
What's subcooling?
How will removing refrigerant help? He has a reciever.
With out a pump down it is possible your getting liquid slugging
shellkamp
I just stated "I don't see a receiver,Is that a receiver drier?"
So.
Still can be overcharged with a receiver.
CRussell1975
So.
Only put in 1Lbs 4 oz.
Pumpdown capacity is 2.5lbs.
Its 85F in the room kinda warm yes.
Pretty sure this is starting components. Everything else checks out ok.
That head looks a bit high to me. I don't know the ambient however
Sooo...
If mine cant start with a little high head pressure..
Then how does every other unit out there with dirty coils start fine?
