Page 6 of 7 FirstFirst 1234567 LastLast
Results 66 to 78 of 79
  1. #66
    Nov 2016
    NYC
    Quote Originally Posted by lkapigian View Post
    The heat out out of the equipment has nothing to do with the efficiency of the structure ...it has to do with OSA DB if I have less heat loss at lower temperature my heat output of the machine remains the same at can keep up with the load at lower temprature ....same as cooling the better the structure the smaller ac can keep up at higher temps
    I know that, I repeated what you stated about making the home more efficient.
  2. Likes lkapigian liked this post.
  3. #67
    Aug 2009
    Beatrice, NE
    If you look at the heat lose of a structure it is a linear process. So as the temperature goes down the heat needed goes down to match. This is why location does not matter. The lose will be the same at 47 degrees whether it is located in Texas or Canada. At 0 the heat lose will be the same in both locations. The output of the same unit at both locations will be the same. The difference comes in where in Texas you may never reach the point where the unit will need the back up heat where as in Canada it will probably quite a bit. I think where the confusion is the house will have more heat lose at design in Canada than Texas because of colder design conditions.
  4. Likes psehunter, lkapigian liked this post.
  5. #68
    Nov 2016
    NYC
    Quote Originally Posted by hvacrmedic View Post
    You have no idea what thermal balance point is, even after posting its definition yourself. Clear your mind, take in a few slow deep breaths.
    The thermal balance point works like this. As the outdoor temp drops the heating capacity required to maintain the indoor temp increases. Unfortunately as the outdoor temp drops the heat pump's capacity drops. As a result an outdoor temperature will be reached where the heat pump must run nonstop just to maintain the indoor temperature, and if the outdoor temp drops any more than that the heat pump will not be able to keep up, and the indoor temp will begin to drop as well. This crossover outdoor temperature is called the thermal balance point. If the temperature is -10 in one location but only 20 in another, this has nothing to do with the balance point other than the fact that you'll be further below the balance point in one location than in the other.
    BTW in reference to a
    post on page one, higher humidity usually results in "less" dense air.
    Gotta read the post I quoted in that to fully understand what I meant. I know its not something you set or change and know it's the point at which your output equals your loss.
  6. Likes lkapigian liked this post.
  7. #69
    May 2014
    Bay Area California
    How does that work?
    I guess you could say less air. Because in the extreme, it would be all water and no air.
    So instead of saying air, let's call it a medium or substance. As the moisture content of this substance increases, and given a normal AC under normal conditions, does this substance remove more or less heat from the outdoor coil?
  8. #70
    May 2014
    Bay Area California
    He'll get it. As The Medic stated, he just needs to step back and relax.
    Quote Originally Posted by BNME8EZ View Post
  9. Likes psehunter, lkapigian liked this post.
  10. #71
    Nov 2016
    NYC
    Correct, I agree, however, we both know you are not getting zero degrees in texas! and yes on your last sentence, if you have more heat loss at design you would have 2 different balance points at a colder design condition! There is a chart that can be made to show that.
  11. Likes lkapigian liked this post.
  12. #72
    Nov 2016
    NYC
    Quote Originally Posted by BBeerme View Post
    I have the book in front of me, I completely get it What BNME8EZ says is right.
  13. #73
    N.J.
    B. Beerme . In post # 52 you are in agreement with me . Correct ?
  14. Likes lkapigian liked this post.
  15. #74
    Aug 2013
    Visalia California 93291
    I going back to my tequila
  16. Likes BBeerme liked this post.
  17. #75
    Jul 2005
    How does that work?
    The water vapor displaces other heavier molecules, reducing the overall density of the gas mixture. Just imagine filling a room with helium (at constant pressure). As the helium content rises the density of the mixture in the room will drop, and the room will gain lift like a helium balloon.
    Less dense air will be poorer at transferring heat from an air over heat exchanger like a finned coil. Aircraft will also have less lift. A helicopter can land on a high peak in dry air, and be unable to get back off the ground later due to higher humidity alone. It has happened, or so I've heard.
  18. Likes BBeerme, lkapigian liked this post.
  19. #76
    Aug 2009
    Beatrice, NE
    The one thing and it is very important in this discussion is we are talking everything being the same for house and equipment only the location is different. We all know that in reality the house in Texas will have a much larger cooling load and the house in Canada will have a much larger heating load so the equipment would be very different which would then cause the houses to have very different balance points. Not because of temperature or location but because of equipment capacity.
  20. #77
    May 2014
    Bay Area California
    That's why I repeatedly said same unit and same structure.
  21. Likes lkapigian liked this post.
  22. #78
    May 2014
    Bay Area California
    If you are trying to say that balance point does not depend on location, then yes.
    Quote Originally Posted by richper View Post
  23. Likes lkapigian liked this post.
