+ Reply to Thread
Results 1 to 19 of 19
Thread: Underground traps
    Jun 2014
    Dover, DE
    Underground traps
    Guess the traps didn't meet grade. No problem, right? Just bury them.
    “I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
    “It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
    Dec 2014
    New Mexico
    At least they won't freeze
    edmonds wa
    I would not bet on that Chev.
    UA Local 32 retired as of Jan 2020
  4. Likes lions_lair liked this post.
  5. #4
    Aug 2013
    N/A
    Stupid question: Why didn't they make a trench, say, 3" deep x 3" wide, line it with 3" sq. U-channel, and run it the length of the base?
  6. #5
    Nov 2011
    CO
    not much else you could do to get them sized right for that unit. the only thing I might have done differently is the trench idea, and turned it into a french drain.
    I've had to cut up concrete floors to get traps deep enough.
  7. #6
    Dec 2014
    New Mexico
    May be they were hoping to get a little free irrigation for the "herb " garden.
  8. #7
    May 2014
    Bay Area California
    The dirt may have been added after the traps were installed.
  9. Likes Juan Madera liked this post.
  10. #8
    Anytown USA
    Lol. They always forget about the drain traps when setting equipment. Ideally, the concrete pad should have been made higher to allow for the drains. It slipped past someone during the design phase.
  11. #9
    Jan 2017
    At least they put traps
  12. #10
    Mar 2013
    Treasure coast, FL
    They could have just run the lines across the sidewalk and made the trap after the street curb. :grin:
    Sent from my SCH-I545 using Tapatalk
  13. #11
    Feb 2017
    New York
    Why not inverted traps?
    OK, I apologise, that was bad.
    Stop, step back, relax and have another go at it.
    -----Stop, step back, relax and have another go at it.-----
  14. #12
    Jul 2013
    Richmond, VA
    It looks like the sidewalk is brand new, so maybe the traps were buried after installation.
  15. #13
    Jun 2014
    Dover, DE
    Whole building is actually brand new. This was one of the most unorganized jobs I've been involved in, ever. When the installer called me to come do startup, he said he was ready and under a lot of pressure as the building was going to have a grand opening in less then a week. When I showed up no ductwork was attached to the machine and the controls hadn't been wired yet. I went back to the site, at midnight, the morning of the dedication to just get the blower and heat running. That was December, I've been waiting on the installer to fix a bunch of leaks so I can get the cooling going.
  16. #14
    up in the hizzy
    Horrible job! why so many traps? looks like they put traps on every hole they found, its that a Season 4?
    There is not better place for the working men than the union! 100% UA the only HVAC union!
  17. #15
    Jun 2014
    Dover, DE
    Quote Originally Posted by valdelocc View Post
    PoolPak
    Normally drainage is plumbed together in each section. So traps in every port isn't needed.
  18. #16
    Feb 2017
    New York
    I get that rider77, but any of the sections were running a higher negative pressure, couldn't the condensate from one flow to the other causing it to overflow? I may be way out in left field on this one... unless you're talking about tying them all together after the trap.
  19. #17
    Jun 2014
    Dover, DE
    Most of the machine your looking at is under positive pressure. That said, the drains that are plumbed together drain equally so the traps will all fill.
    That said having all these traps is not necessary. But shouldn't hurt anything.
  20. #18
    Feb 2016
    Louisburg Kansas
    rider77 you stating how disorganized the job was reminded me of a job I was asked to do the air balance on. When I got to the building the windows and doors had not been installed and only the rough-in ductwork was done. I called the installer and told him the building wasn't done and his brilliant answer was "it is closer than it was last week". Sadly enough we have all been there.
  21. #19
    Feb 2017
    New York
    OK, sorry, didn't realize those were positive pressure condensate drains. I agree.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
